MHB Understanding a problem in ring theory
  • Thread starter Thread starter kalish1
    Ring Theory
kalish1
Can someone here help me fill in the gaps of my understanding for this problem? I would appreciate it.
**Problem:** If $f(x) \in \mathbb{C}[x]$ is a nonzero polynomial of degree $n$, prove that the ring $R=\frac{\mathbb{C}[x]}{(f)}$ has finitely many distinct ideals. How many distinct ideals does it have?
**Teacher's explanation:** $$R=\frac{\mathbb{C}[x]}{(f)} \longleftarrow \frac{J}{(f)}$$ means that $J \supseteq (f).$
*She mentioned that $(u \cdot g) = (g)$, but I don't see how.*
Now, $\frac{(g)}{(f)}$ where $(g) \supseteq (f)$, implies that $f \in (g)$. Thus $f$ is a multiple of $g$ and $g|f$. Thus $g$ is a monic divisor of $f$. Note that $f=c(x-x_1)(x-x_2)\cdots(x-x_n)$ by the Linear Factorization Theorem. Now we count the monic divisors of $f$, which turns out to be:
$$ 1, (x-x_1), \ldots, (x-x_n)$$ and all products of the linear factors. Thus there are $2^n$ distinct ideals.
**My questions:**
What does $R=\frac{\mathbb{C}[x]}{(f)} \longleftarrow \frac{J}{(f)}$ mean? Why is $(u \cdot g) = (g)?$ How does counting the monic divisors of $f$ correlate with the number of distinct ideals?
Thanks.
This question has been crossposted here: abstract algebra - Understanding a problem in ring theory - Mathematics Stack Exchange
Hi,
I haven't seen before that notation with the arrow, I guess is just saying $J$ being an ideal on the quotient implies $J$ is an ideal of $C[X]$ which contain $(f)$.
$(u\cdot g)=(g)$ I suppose $u\in \mathbb{C}$, and that means we can always consider a monic generator for any ideal.
$\mathbb{C}[X]$ is an Euclidean domain, so also a $PID$, and $(f)\subset (g)$ means that there exist some polynomial $h$ such that $f=gh$ so $g$ is a divisor of $f$, and monic for the reason above.
Fallen Angel said:
Hi,
We haven't learned about domains or PIDs yet, and I'm still unsure of how $(u\cdot g)=(g).$ Also, where does the Correspondence Theorem come into play? Could you please elaborate with some examples?
Hi Kalish,
I will state a couple of theorems that I was assuming you know, let me know if you have heard about it or have some trouble proving it.
Theorem 1
If $K$ is a field, then $K[X]$ is an euclidean domain, i.e. for any given polynomials $f(x),g(x)\in K[X]$ there exists two polynomials $q(x),r(x)\in K[X]$ such that
$\bullet$ $f(x)=g(x)q(x)+r(x)$
$\bullet$ $deg(r)\leq deg(g)-1$
Furthermore, this polynomials are unique.Theorem 2 (Bezout's identity restricted to $K[X]$)
Let $K[X]$ be the ring of polynomials over a field and let $f_{1},f_{2},\ldots f_{n}\in K[X]$ be a finite set of polynomials such that $gcd(f_{1},f_{2},\ldots ,f_{n})=h$, then there exists $g_{1},g_{2},\ldots g_{n}\in K[X]$ such that
$h=\displaystyle\sum_{i=1}^{n}f_{i}g_{i}$
Theorem 3
Let $R$ be a ring and $I\subset R$ an ideal, if $a\in R^{*}$ then $I=aI$, where $R^{*}$ is the set of all elements in $R$ that have an inverse with respect to the multiplication.
Theorem 4
Let $R$ be a ring and $I\subset R$ an ideal, and $\pi_{I}: R \longrightarrow R/I$.
$\hspace{8cm} r \ \ \mapsto \ r+I$
Then $J\subseteq R/I$ is an ideal of the quotient ring if and only if it there exists an ideal $J'\subseteq R$ containing $I$ such that $\pi_{I}(J')=J$.
Thanks for that. Do you think $2^n$ is correct for the number of distinct ideals?
Fallen Angel said:
Hi Kalish,
Theorem 1
Theorem 3
Theorem 4
No, it makes no sense.
The number of ideals will be the number of monic divisors of the polinomyal, so it can be just 2 if the polyomial is irreducible or whatever if not.
The four theorems above are the way to prove it. (They are the hidden facts in you first prove)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
