K29
- 108
(Source: page 20 of this :http://www.ics.uci.edu/~bic/courses/JaverOS/ch2.pdf)
The part I put in bold looks like nonsense.
Since program1 executes after the Critical Section and after turn gets set to 2, there is nothing stopping p2 from leaving its wait loop and entering its critical section, no matter what happens in program1. Looks like a perfectly fine solution to me.
Am I right? Am I not seeing something?(NOTE: p1 is the thread and program1 is the non-critical part of p1.)
The problem is easily solved if we insist that p1 and p2 enter their critical sections alternately; one common variable, turn, can keep track of whose turn it is. This idea is implemented in our first algorithm below.
Code:/* CS Algorithm: Try #1 */ int turn = 1; cobegin p1: while (1) { while (turn==2) ; /*wait loop*/ CS1; turn = 2; program1; } // p2: while (1) { while (turn==1) ; /*wait loop*/ CS2; turn = 1; program2; } coend
Initially, turn is set to 1, which allows p1 to enter its CS. After exiting, the process sets turn
to 2, which now allows p2 to enter its CS, and so on. Unfortunately, if program1 were much longer than program2 or if p1 halted in program 1, this solution would hardly be satisfactory. One process well outside its critical section can prevent the other from entering its critical section, thus violating the requirement 1 stated above
