Understanding black body radiation
In summary, the field of quantum mechanics was launched as scientists struggled to understand the source of blackbody radiation. This radiation is a result of the electrons in the metal making transitions between different energy states, as well as transitions in molecules. Planck was able to model the walls of the cavity as an ensemble of oscillators exchanging electromagnetic radiation, and through his work, he discovered the concept of energy quanta. This led to the development of modern quantum theory, which is the only valid theory we have today for matter and radiation. Blackbody radiation is in thermal equilibrium with the walls of the cavity, with the wiggling of charges being maximally randomized. This equilibrium situation reflects the most random state given the constraint of energy conservation.
Sophrosyne
128
The field of quantum mechanics was launched with scientists struggling to understand blackbody radiation.
My question is: what is the source of this observed radiation? Is it the nuclei in the matrix of the metal jiggling around ever more energetically as you heat up the metal? Or is it the electrons getting shot up to higher energy orbitals and then falling back down, like with the spectroscopy seen when you zap hydrogen gas with an electric arc?
Thanks.
The electrons in the metal also make transitions between different energy states - the states are just much more spread out.
All transitions contribute to black body radiation. Transitions in molecules are another contribution together with the two you mentioned.
The great thing with blackbody radiation in the sense studied by Planck is that it doesn't matter where it comes from. It's radiation in thermal equilibrium with the cavity walls it is confined to. The only thing you need to know that the cavity walls consist of electrically charged particles that are somehow bound within the walls and that electromagnetic fields make the charges wiggle around as well as that wiggling (i.e., accelerated) charges emit electromagnetic waves. Thus the electromagnetic radiation gets absorbed and emitted all the time. In thermal equilibrium the wiggling of the charges is maximally randomized, and if also the radiation within the cavity is in thermal equilibrium with the walls the emission and absorption rates are equal, i.e., there's no net exchange of energy between the radiation field and the walls. This equilibrium situation reflects the most random state (maximum-entropy state) given the contraint of energy conservation, which is embodied in the thermo-statistical treatment of the problem by the temperature of the walls and radiation field.
This was well known when Planck started to attack the problem in the late 1880ies. I.e., he could model the walls as an ensemble of harmonic oscillators exchanging electromagnetic radiation. Around 1900 he also got new high-precision input from a very careful measurement of the black-body spectrum as a function of temperature by Lummer and Kurlbaum at the Physikalisch Technische Reichsanstalt (PTR), who undertook this endeavor to get a well-calibrated measure for the luminosity of light for engineering the lightning (particularly the upcoming electric light bulbs in this time).
As is well known, Planck first got an empirical formula interpolating the older attempts (Wien vs. Rayleigh-Jeans) which turned out to be only correct in the long-wavelength and the large-wavelength limit but not over the whole spectral range. A bit later Planck tried to get his empirical formula from first principles of thermodynamics (his true field of expertise) and electromagnetic theory (Maxwell's equations), using (reluctantly!) the methods of statistical mechanics a la Boltzmann and Maxwell, which he didn't appreciate much at the time. Using a mathematical trick by Boltzmann "quantizing the energy" he figured out that he had to quantize the absorption and emission energies of the radiation field with his model-matter oscillators as to exchange "energy packets" of the size ##\hbar \omega## (written in modern terms using the modified Planck constant ##\hbar##), where ##\omega## is the frequency of the radiation. To his surprise he got the right formula by using this assumption and counting the number of ways to distribute of the total energy of the radiation field in the cavity in corresponding microstates, and that one must not take the continuum limit of energy exchange, which was his final goal since in classical electrodynamics the radiation energy should be absorbed and emitted in a continuous way, but he had to keep his "energy quanta", i.e., ##\hbar## finite to fit the black-body spectrum found by the PTR researches with high accuracy over the complete range of the spectrum.
The rest is then a known story. After some confusion (called the "old quantum theory") finally in 1925/26 the physicists discovered modern quantum theory, including also relativistic quantum field theory, although it should take another 20 years to make sense of the divergent higher-order quantum corrections in terms of renormalization theory, which indeed was fully understood only at the end of the 1960ies and early 1970ies with the work by Bogoliubov, Parasiuk, Hepp, and Zimmermann who developed the systematics of renormalization using Feynman diagrams and 't Hooft's and Veltman's proof of the renormalizability of gauge theories. This is the best and only valid theory we have about matter and radiation today. Particularly photons cannot be adequately described by any other model than relativistic QFT itself.
Likes odietrich
Thanks for the response. A
houldnt there be different peaks for all the different
Thanks.
thanks for the responses.
That sentence looks incomplete.
Real materials are not perfect blackbodies, but to get peaks you need something that excites the atoms more than thermal radiation would do.
Related to Understanding black body radiation
1. What is black body radiation?
Black body radiation refers to the electromagnetic radiation emitted by a perfect black body, which is an idealized object that absorbs all radiation that falls on it. It is also known as thermal radiation because it is produced as a result of the temperature of the object.
2. What causes black body radiation?
Black body radiation is caused by the thermal energy of the object. As the temperature of the object increases, the atoms and molecules within it vibrate and emit electromagnetic radiation in the form of photons.
3. How does black body radiation relate to temperature?
The intensity and distribution of black body radiation is directly related to the temperature of the object. As the temperature increases, the peak wavelength of the radiation shifts towards shorter wavelengths, and the overall intensity of the radiation also increases.
4. What is the significance of understanding black body radiation?
Understanding black body radiation is important in a variety of fields, including physics, astronomy, and engineering. It allows us to predict the behavior of objects at different temperatures and wavelengths, and is essential for developing technologies such as thermal imaging and solar panels.
5. How is black body radiation measured?
Black body radiation is measured using a spectrophotometer, which measures the intensity of radiation at different wavelengths. The data is then plotted on a graph called a black body curve, which shows the relationship between the intensity and wavelength of the radiation emitted by the object.
  • Quantum Physics
  • Quantum Physics
  • Other Physics Topics
