MHB Understanding Bland's Proposition 4.2.10 in Rings and Modules
The discussion centers on understanding Proposition 4.2.10 from Paul E. Bland's "Rings and Their Modules," specifically the proof involving ascending chains of submodules. The key point is the demonstration that if \( M \) is decomposable, it can be expressed as a series of direct sums, such as \( M = X \oplus Y \), where \( X \) can be further decomposed into \( X' \oplus Y' \), and so on. This leads to the conclusion that \( Y \subseteq Y \oplus Y' \) and \( Y \oplus Y' \subseteq Y \oplus Y' \oplus Y'' \), establishing the ascending chain of submodules. Additionally, it is clarified that \( Y \oplus Y' \) is indeed a submodule of \( M \) as both \( Y \) and \( Y' \) are submodules. The conversation emphasizes the importance of recognizing the structure of direct sums in the context of module theory.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am focused on Section 4.2: Noetherian and Artinian Modules and need some further help to fully understand the proof of part of Proposition 4.2.10 ... ...
Proposition 4.2.10 reads as follows:View attachment 8215In the above proof by Bland we read the following:
" ... ... Continuing in this way we obtain an ascending chain $$Y \subseteq Y \oplus Y' \subseteq Y \oplus Y' \oplus Y'' \subseteq$$ ... ... "Can someone please explain in some detail exactly how/why $$Y \subseteq Y \oplus Y'$$ and $$Y \oplus Y' \subseteq Y \oplus Y' \oplus Y''$$ etc ...
Help will be appreciated ...
Peter
=========================================================================Definition 4.2.9 is relevant to the above post so I am providing the text of Definition 4.2.9 ... as follows ... View attachment 8216=========================================================================
It is supposed that $M$ is decomposable but cannot be written as finite direct sum
$$M = M_1 \oplus M_2 \oplus \cdots \oplus M_n$$
of indecomposable submodules $M_i \leq M$
$M$ is decomposable so $M$ can be broken into two submodules, say $M = X \oplus Y$.
This is a finite direct sum (by hypothesis $M$ cannot be a finite sum of indecomposable submodules), so one of the submodules is not indecomposable, say $X$ is not indecomposable. Thus $X$ can be broken into two submodules say $X = X’ \oplus Y’$. Thus $M = X’ \oplus Y’ \oplus Y$.
Again this is a finite direct sum, so one of the submodules is not indecomposable, say $X’$ is not indecomposable. Thus $X’$ can be broken into two submodules say $X’ = X’’ \oplus Y’’$. Thus $M = X’’ \oplus Y’’ \oplus Y’ \oplus Y$.
Again this is a finite direct sum, so one of the submodules is not indecomposable, say $X’’$ is not indecomposable. Thus $X’’$ can be broken into two submodules say $X’’ = X’’’ \oplus Y’’’$. Thus $M = X’’’ \oplus Y’’’ \oplus Y’’ \oplus Y’ \oplus Y$.
And so on $\cdots$
The sequence starts with breaking $M$ into two submodules,
Each time the “$X$”-module is supposed to be not indecomposable:
$M = X \oplus Y$, then $X = X’ \oplus Y’$, so
$M = X’ \oplus Y’ \oplus Y$, then $X’ = X’’ \oplus Y’’$, so
$M = X’’ \oplus Y’’ \oplus Y’ \oplus Y$, then $X’’ = X’’’ \oplus Y’’’$, so
$M = X’’’ \oplus Y’’’ \oplus Y’’ \oplus Y’ \oplus Y$ and so on $\cdots$
Of course $Y \subset Y \oplus Y’ \subset M$
and $Y \oplus Y’ \subset Y \oplus Y’ \oplus Y’’ \subset M$
and $Y \oplus Y’ \oplus Y’’ \subset Y \oplus Y’ \oplus Y’’ \oplus Y’’’ \subset M$
and so on, thus
$ Y \subset Y \oplus Y’ \subset Y \oplus Y’ \oplus Y’’ \subset Y \oplus Y’ \oplus Y’’ \oplus Y’’’ \cdots $
And so on $\cdots$
and so on, thus
Thanks for the help, Steenis ...
Will be working through your post in detail shortly ...
Peter
And so on $\cdots$
and so on, thus
Thanks steenis ... I think I have understood all that you wrote ...
An explicit proof of $$Y \subseteq Y \oplus Y'$$ follows ...
$$Y = \{ y \ \mid y \ \in Y \}$$ $$Y \oplus Y' = \{ y + y' \ \mid \ y \in Y , y' \in Y' \} $$
Show $$Y \subseteq Y \oplus Y' $$
$$y_1 \in Y $$
$$\Longrightarrow y_1 + 0_{ Y' } \in Y \oplus Y' $$
$$\Longrightarrow y_1 \in Y \oplus Y'$$
$$\Longrightarrow Y \subseteq Y \oplus Y'$$------------------------------------------------------------------------------------------------------------------
*** What confused me was thinking that since we are dealing with a finite direct sum we have
$$Y \oplus Y' \cong Y \times Y'$$
and viewed in this way $$Y \oplus Y' = \{ (y, y') \ \mid \ y \in Y , y' \in Y' \}$$
... and then it is difficult to see how $$Y \subseteq Y \oplus Y'$$
... but I guess the answer is to realize that $$Y \times Y' \cong Y + Y'$$ ... (Dummit and Foote, page 353)
Now (I think) that Theorem 4.2.10 assumes that $$Y \oplus Y'$$ is a submodule where $$Y, Y'$$ are both submodules of M ...So ... we need to demonstrate that $$Y \oplus Y'$$ is a submodule where $$Y, Y'$$ are both submodules of $$M$$ ...So ... let $$x, y \in Y \oplus Y'$$ and $$a \in R$$ ...
Then ... $$x = x_1 + x_2$$ where $$x_1 \in Y$$ and $$x_2 \in Y'$$ ... ...
... and ... $$y = y_1 + y_2$$ where $$y_1 \in Y$$ and $$y_2 \in Y'$$ ... ...
... then $$x + y = ( x_1 + x_2 ) + ( y_1 + y_2 )$$
$$\Longrightarrow x + y = ( x_1 + y_1 ) + ( x_2 + y_2 )$$
But $$( x_1 + y_1 ) + ( x_2 + y_2 ) \in Y \oplus Y'$$ ... since both $$Y$$ and $$Y'$$ are submodules ...
$$\Longrightarrow x + y \in Y \oplus Y'$$
... and ...
$$xa = ( x_1 + x_2 ) a = x_1 a + x_2 a \in Y \oplus Y'$$ ... since both $$Y$$ and $$Y'$$ are submodules ... Since $$x+ y$$ and $$xa$$ $$\in Y \oplus Y'$$ we have that $$Y \oplus Y'$$ is a submodule of $$M$$ ...
Is that correct ...?
Peter
The first part is ok.
What you have proven in the second part is ok, but has already been proven in proposition 1.4.4.
We are dealing with internal direct sums here, so we can use the "sum"-notation.
If $Y$ and $Z$ are modules, then we can say that $Y$ is a submodule of the external direct sum $Y \times Z$ if we consider $Y$ as $Y \times 0$, in fact $Y \cong Y \times 0$ and $Y \times 0$ is a submodule of $Y \times Z$.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
