Understanding bulk fluid motion under Lorentz force
In summary, the Lorentz force affects bulk fluid motion by causing an increase in the z-axis and the radius of the cyclotron effect, and to produce a perpendicular force, the electric and magnetic field vectors must be at 90 degrees to each other.
MagnetoBLI
43
I am trying to understand how the Lorentz force affects bulk fluid motion when I have an applied electric field (y-axis), applied magnetic field (x-axis) and bulk fluid velocity (z-axis), all orthogonal to each other.
I understand that if the fluid was at rest, an electrostatic force would generate a velocity in the y-axis, which would also generate a Lorentz force/velocity in the z-axis and form the cyclotron effect.
However, when the bulk fluid velocity in the z-axis exists, I presume this flow cannot be considered a moving charge (as both ions and electrons are travelling) and therefore the only moving charge is associated with the electric field. Instead a dynamo effect would take place such that the momentum force of the z-axis fluid flow would generate a current in the negative y-axis (should be negative in the image) and this current would in turn produce a force in the z-axis, thus accelerating the bulk fluid motion. Therefore the net effect would be to increase the radius of the cyclotron affect in the z-axis. Is this correct?
Could you tell me where the magnetic and electric field vectors should be to produce a force perpendicular to the bulk fluid motion (right schematic in the attachment)?
Any comments are much appreciated.
Cheers.
Attachment found in: https://www.physicsforums.com/showthread.php?t=665859
Yes, that is correct. The Lorentz force will cause the bulk fluid motion to increase in the z-axis, thus increasing the radius of the cyclotron effect. To produce a force perpendicular to the bulk fluid motion, the electric and magnetic field vectors must be at 90 degrees to each other, with the electric field pointing in the y-axis and the magnetic field pointing in the x-axis.
FAQ: Understanding bulk fluid motion under Lorentz force
What is the Lorentz force?
The Lorentz force is the force exerted on a charged particle (such as an ion or electron) when it is moving in a magnetic field. It is perpendicular to both the direction of the particle's motion and the direction of the magnetic field.
How does the Lorentz force affect fluid motion?
The Lorentz force can cause fluid motion when a magnetic field is applied to a conducting fluid. This is because the charged particles in the fluid experience a force and begin to move, dragging the rest of the fluid with them.
What factors influence the strength of the Lorentz force?
The strength of the Lorentz force depends on several factors, including the strength of the magnetic field, the velocity of the charged particles, and the charge of the particles. It also depends on the direction of the magnetic field relative to the direction of motion of the particles.
How is the Lorentz force used in practical applications?
The Lorentz force is used in a variety of applications, including electromagnetic pumps and motors, particle accelerators, and magnetohydrodynamic power generation. It is also important in understanding the dynamics of fluids in space, such as the solar wind.
What are some challenges in understanding bulk fluid motion under Lorentz force?
One of the main challenges in understanding bulk fluid motion under Lorentz force is the complexity of the equations involved. These equations are highly nonlinear and can be difficult to solve. Additionally, the behavior of the fluid can be highly turbulent, making it difficult to accurately predict and model. Experimental validation is also often required to fully understand the effects of the Lorentz force on fluid motion.
