A Understanding Cantor set C in Ternary form with 1/n factor in front C
  • A
  • Thread starter Thread starter cbarker1
    Cantor Form Set
cbarker1
MHB
TL;DR Summary
I am trying to comprehend the Cantor set C with a 1/n factor in base 3
Dear Everybody,
I am confused by ##1/n C##, where C is a cantor set in base 3 and ##n\geq2##. I can understand the construction of the normal Cantor set.
How do I comprehend this set with this extra condition. Do I multiply the set with ##1/n## or not?
Thanks,
Cbarker1
mentor note: adjusted latex to use double # instead of single #
cbarker1 said:
Understanding Cantor set C in Tetany form with 1/n factor in front C
I have never seen the word "Tetany" before: do you mean "ternery"? Even with this correction I'm afraid the rest of the post doesn't make much sense to me.
Do you have a reference for the ideas you are talking about?
If not, can you provide a more complete description of the set avoiding ambiguous notation like ##1/n C## which whether in ## \LaTeX ## or plain text can mean either ## \frac{1}{nC} ## or ## \frac{1}{n}C ##. Perhaps you could start by rephrasing "The Cantor ternary set is created by iteratively deleting parts of a set of line segments. One starts by deleting the open middle third ## \left ( \frac{1}{3} , \frac{2}{3} \right) ## from the interval ## [ 0 , 1 ] ##."
I changed "tetany" in the thread title to "ternary," as my best guess as to what the OP was trying to convey.
Also, perhaps the "1/nC" (with same complaint about what 1/nC actually means) is meant to convey the level of middle third deletions. Again, that's a guess. If so, with n = 1, we would have the two subintervals [0, .1] and [.2, 1], using base-3 fractions. With n =2, we remove the middle third from each of the two previously listed subintervals. This would produce four subintervals: [0, .01], [.02, .1], [.2, .21], and [.22, 1], again using base-3 fractions.
And so on.
your guesses are right. I want that word Ternary and ##(1/n)*C##.
OK, so how much of the set do you remove at the first iteration?
How much at the second?
How much at the ## n ##th?
How much in total as ## n \to \infty ##?
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
