Understanding Capacitor Voltage and Capacity in a Circuit
  • Thread starter Eitan Levy
  • Tags
    Capacitors
In summary: Some of what is not explicitly stated:The second capacitor is placed across the first - in parallel.The second capacitor starts out discharged.So the voltage is going to be proportional to the charge and inversely proportional to the total capacitance.The charge does not change, so the capacitance must increase by 60/40, a factor of 1.5.The current through the resistor is limited to that which can flow through the resistor.
Eitan Levy
259
First, we connect a capacitor to a voltage source with an electric force of 60V.
After that we put another capacitor with a capacity of 0.01nF instead of the voltage source. As a result, the voltage on the first capacitor is down to 40V.
1. What is the voltage on the second capacitor?
2. What is the capacity of the first capacitor?
This is a very new topic for me. Why the voltage on the second capacitor is 40V and not 20V and how can we calculate the capacity? (Maybe it's 40V because of Kirchhoff's voltage law?)
Thanks in advance.
Sorry, the second capacitor is not charged at first.
This is how it looks:
Hi,
Not nicely following the PF guidelines , this post is.
But I'll help you get started:
With resistors, you have V = I R
With resistors in parallel, the voltages over each of the resistors are identical.
With resistors in series, the current through each of the resistors is the same.
With capacitors, you have Q = C V
So if you charge your first capacitor, it carries Q1 = C1 V1 where V1 is known, C1 is not and Q1 isn't either.
If you then replace the voltage source by an (uncharged) capacitor, the charge will redistribute over the two capacitors until the voltages are the same (because the charge can't go anywhere else -- and the two capacitors are parallel).
You have one V2 (40 V) and two C, one C2known, one C1 unknown. But you can write:
Q2=C1V2 + C2 V2
Since the charge hasn't gone anywhere else, Q2 = Q1
Three equations, three unknowns. Bingo.
This doesn't give the correct answer. The capacity is 0.02nF.
It does give the correct answer.
You have to reason: C1 + C2 = 1.5 C1 with C2 known
BvU said:
Hi,
Q2=C1V2 + C2 V2
Thank you, but I still don't understand how you can say that Q1=Q2
BvU said:
Hi,
Q2=C1V2 + C2 V2
Wait, do you mean that the current can only be like that? I don't understand.
The 60V deposited a charge on C1. Then the 60V was disconnected - leaving that charge (and voltage) on C1.
Then C2 was connected to C1, allowing that fixed charge to be shared by the two capacitors.
So unless I connect another voltage source, the sum of the charges stays the same?
Can you explain why?
Yes. That charge is an actual difference in the number of electrons and/or electron holes between one side of the capacitor and the other. When you connect the two capacitors, some of those electrons and electron holes travel to that second capacitor. But the total number (the net difference from one side to the other) does not change.
And their movement is like that?
Thank you so much!
Close enough.
Remember that the voltage applied to C1 was positive and electrons are negative. So when C2 is applied, electrons actually travel from its positive side to C1, making C2 more positive and C1 less positive. In the same way that there would be a brief current between the positive sides of C1 and C2, there would also be current between the "ground" side of those capacitors.
Related to Understanding Capacitor Voltage and Capacity in a Circuit
1. What is a capacitor?
A capacitor is a passive electronic component that stores electrical energy in an electric field. It consists of two conductive plates separated by an insulating material known as a dielectric.
2. How does a capacitor work?
When a voltage is applied to a capacitor, the electric field between the plates is established, causing one plate to accumulate positive charge and the other to accumulate negative charge. This results in the storage of electrical energy in the form of potential energy.
3. What is the unit of capacitance?
The unit of capacitance is Farad (F), named after the English physicist Michael Faraday. One Farad is equal to one coulomb of charge per volt of potential difference between the plates of a capacitor.
4. What are the different types of capacitors?
There are various types of capacitors, such as ceramic, electrolytic, film, and variable capacitors. Each type has its own unique characteristics, and they are used in different applications based on their properties.
5. How do you calculate the capacitance of a capacitor?
The capacitance of a capacitor can be calculated by dividing the charge on one plate (Q) by the potential difference between the plates (V). This is represented by the equation C = Q/V. The capacitance value is also affected by the size, distance, and material of the plates, as well as the type of dielectric used.
