Understanding Capacitors - Form & Function
In summary: P = IRW.[3]If i was designing a circuit that required a certain frequency filter, what would help me decide on the Capacitor type and rating and the resitor type and rating?.If you were designing a circuit that required a specific frequency filter, you would need to find a resistor and capacitor with the right specifications to achieve the desired frequency. For a capacitor, you would need to know the capacitance (in Farads) and the voltage rating (in volts). For a resistor, you would need to know the wattage and the resistance.
3trQN
337
Hello peeps, I am currently studying capacitors and simple electronic circuit design, but I am getting the feeling I am not quite fully understanding things because i keep forgetting key concepts and how they fit together in an abstract sense.
(please forgive the long post, its an attempt to get everything out and shake out any misunderstandings and uncertainties, I'll Add my succinct questions to the end)
Some Background:
I am trying to learn what capacitors are used for, and how to go about selecting the right capacitor for a given problem or circuit design.
I understand that capacitors are used for storing charge and as filters, in the form of band-pass/stop high/low-pass filters. I believe that this filtering is due to the frequecy response of the capacitor as an oscillating system, in which it takes time to fully charge a capacitor plate and that this is a property of the capacitor material and the current and voltage. I think of this analogus to a pendulum oscillating system attached to some damping device.
I have learned how a capacitor stores charge by seperating charges with a dielectric (non-conducting) material, and that there exists an electric field between any two separated charges. The energy held by a capacitor is a measure of the potential work that the capacitor can do, when the separated charges are allowed to flow back to equillibrium.
I believe that i am correct in saying it is and applied voltage across the capacitor that maintains the charge separation across the dielectric material?
In terms of circuit design i have seen how a capacitor may be used in conjunction with a resitor to create a filter, but i can't say i fully understand how the two components work to achieve this.
Im terribly confused. I don't quite understand what an electric field is, other than a seemingly abstract concept which sais that "If you roll this ball of charge away from that ball of charge, then the work you put in you will get out eventually when they roll back together again" (conservation of charge & energy laws).
So my main Questions:
  • [1]What properties make a good dielectric material? (on a molecular and/or subatomic level of detail).
  • [2]In a resistor, electrical charge is converted to thermal energy, by what mechanism is this acheived? (again, this is mostly a question of molecular mechanics i guess).
  • [3]If i was designing a circuit that required a certain frequency filter, what would help me decide on the Capacitor type and rating and the resitor type and rating?.
(you'll notice my complete lack of mathematical skill here, sorry in advance)
In that case you should probably suspend study about capacitors for now and read about electric fields and forces. Mathematically speaking, an electric field is just a vector function of three dimensional space. Physically speaking, it is the force experienced by a unit positive charge when it is placed in a region where the field exists.
  • To quote from wikipedia (http://en.wikipedia.org/wiki/Dielectric_materials#Some_practical_dielectrics)
    Dielectric materials can be solids, liquids, or gases. In addition, a high vacuum can also be a useful, lossless, dielectric even though its relative dielectric constant is only unity.
    Solid dielectrics are perhaps the most commonly used in electrical engineering and many solids are very good insulators. Some examples include porcelain, glass, and most plastics. Air, nitrogen and sulfur hexafluoride are the three most commonly used gaseous dielectrics.
    * Industrial coatings such as parylene provide a dielectric barrier between the substrate and its environment.
    * Mineral oil is used extensively inside electrical transformers as a fluid dielectric and to assist in cooling. Dielectric fluids with higher dielectric constants, such as electrical grade castor oil, are often used in high voltage capacitors to help prevent corona discharge and increase capacitance.
    You can also google this up (sorry this is not an adquate response to quetson 1).
    [*][2]In a resistor, electrical charge is converted to thermal energy, by what mechanism is this acheived? (again, this is mostly a question of molecular mechanics i guess).
    Electrical charge is not converted to thermal energy! Charge flows in the circuit and is conserved. Flow of charge gives rise to a current which causes Joule heating (dissipation of energy) in a resistor. As a current I flows through a resistor of resistance R, a potential difference V = IR (assuming Ohm's law) develops across the two terminals of the resistor. The power dissipated in the resistor is equal to [itex]V\timesI = I^{2}R = V^{2}/R[/itex].
No, it's not. Electric charge is never created or destroyed in a circuit, it's simply moved around from one place to another. The thermal energy that appears in a resistor comes from electrical potential energy associated with the charge. As the charge (electrons) flow through a resistor, they lose some of their electrical potential energy, which becomes kinetic energy of the random motions of the molecules of the resistor, i.e. thermal energy.
If you're studying electronics from a source (textbook or Web site or whatever) that doesn't go into the underlying physics, you should pick up a decent undergraduate introductory physics textbook. New ones are expensive, but a fifteen-year-old used one will work fine. These parts of physics haven't changed in over a hundred years, after all. :smile: You'll find that they cover energy, electric forces and fields, and electric potential energy, and then cover capacitors, electric circuits, etc. as applications of those concepts. It sounds like you're trying to do it backwards.
Appologies, the dissipation of heat by a resistor is what i was thinking of. By what process is this heat dissipated from the flow of charge according to the power law?
I am familiar with Coulombs law for point charges and the electric field, to some extent.
Thanks for the reply. Your right i don't fully understand electrical fields, i find the concepts self referencial. I'll just have to bang my head some more and hope it goes in eventually.
The US military put out a book on hands-on electronics (around WWII, I think) called The Radioman's Guide. It's a decent basic no-frills book on basic electronics and I used it to help me understand basic circuits before tinkering on my own guitar amps and eventually those of others, too. You can probably find copies in used book stores and libraries.
Related to Understanding Capacitors - Form & Function
1. What is a capacitor?
A capacitor is an electrical component that stores energy in an electric field. It is made up of two conductive plates separated by a non-conductive material, called a dielectric.
2. How do capacitors work?
Capacitors work by storing electrical charge on their plates. When a voltage is applied across the plates, one plate becomes positively charged and the other becomes negatively charged. The dielectric material between the plates prevents the charges from flowing together, creating an electric field and storing energy.
3. What are the different types of capacitors?
There are several types of capacitors, including ceramic, electrolytic, film, and tantalum. They differ in their construction materials, dielectric materials, and applications. Ceramic capacitors are commonly used in high-frequency circuits, while electrolytic capacitors are used for high capacitance values. Film capacitors are used in precision circuits, and tantalum capacitors are used for their low leakage and high stability.
4. How do I choose the right capacitor for my circuit?
To choose the right capacitor for your circuit, you need to consider factors such as capacitance, voltage rating, and temperature stability. The capacitance value should match the requirements of your circuit, and the voltage rating should be higher than the maximum voltage in your circuit. Temperature stability is important for circuits that operate in extreme temperatures.
5. What are some common applications of capacitors?
Capacitors have a wide range of applications, including power supply filtering, energy storage, timing circuits, and noise reduction. They are also used in electronic devices such as televisions, computers, and smartphones. In addition, capacitors are used in motor starting and run circuits, as well as in audio equipment for signal coupling and filtering.
  • Electromagnetism
12K
  • Electromagnetism
  • Electromagnetism
