Understanding Cardano's method of solving Cubic equation
In summary, Cardano's method to solve the cubic equation is to make two substitutions, and then solve for two solutions. This results in a quadratic equation, which can be solved to get two solutions.
PcumP_Ravenclaw
106
Dear All,
I am trying to understanding Cardano's method to solve the cubic equation. Please first see the reference text that is attached (Alan F. Beardon, Algebra and Geometry).
My rough understanding is that we make 2 substitutions (## P1(z - a/3)## and ##P(z - b/z) ## ) to simplify the cubic equation to the from (## z^6 -cz^3 - b^3 = 0 ##) so that we can make a further substitution (## y = z^3##). This results in a quadratic equation which can be solved to get two solutions y1 and y2.
## z^3 = y1## or ##y2 ## say y1 and y2 are 8 and -8 then this results in only two solutions right 2 and -2. Without forgetting that we need to do 2 Reverse substitutions to get the final solution. Why does the book say 6 solutions for z and only 3 are distinct?
In the paragraph below from the text.
" However, the values of ζ are the
roots of the equation ## z^6 − cz^3 − b^3 = 0## , and if v is a root of this equation,
then so (trivially) is v1 = −b/v. As v1 − b/v1 = v − b/v, we see that these six
values of ζ can only provide at most three distinct roots of p. "
what is v and v1. why is v1 = -b/v (The substitution was ##P(z - b/z) ## ) ??
I think the coefficients, a, b & c from the equation 3.6.1 and the equation below 3.6.1 in the text are NOT the same as the original cubic equation (## z^3 + az^2 + bz + c = 0 ##). I cross-referenced equation 3.6.1 with equation 12 from http://mathworld.wolfram.com/CubicFormula.html. I don't think the coefficients are the same. Are they??
Danke...
PcumP_Ravenclaw said:
z3=y1ory2 z^3 = y1 or y2 say y1 and y2 are 8 and -8 then this results in only two solutions right 2 and -2. Without forgetting that we need to do 2 Reverse substitutions to get the final solution. Why does the book say 6 solutions for z and only 3 are distinct?
In the complex numbers, z^3 = y always has three distinct solutions (let's ignore the case y=0). Therefore, you get up to 6 solutions. At most 3 are relevant for the final solutions.
what is v and v1.
Solutions to the equations discussed above.
why is v1 = -b/v
Definition. It is like a statement "if n is an integer, then m=n+1 is an integer": "if v is a solution, then v1=-b/v is a solution" (check this!).
b and c are not the original b and c, right.
Likes PcumP_Ravenclaw
Here is my understanding of Cardano's method: If a and b are any numbers then [itex](a+ b)^3= a^3+ 3a^2b+ 3ab^2+ b^3[/itex] and [itex]3ab(a+ b)= 3a^2b+ 3ab^2[/itex]. Subtracting, [itex](a+ b)^3- 3ab(a+ b)= a^3+ b^3[/itex].
Letting x= a+ b, m= 3ab, and [itex]n= a^3+ b^3[/itex] then x satisfies the reduced cubic [itex]x^3+ mx= n[/itex] ("reduced" because it has no squared term). Now, what about the other way around? That is, if we know m and n, can we find a and b and so x?
Yes, we can. From [itex]m= 3ab[/itex], we have [itex]b= \frac{m}{3a}[/itex] so that
[tex]n= a^3+ b^3= a^3+ \frac{m^3}{3^3a^3}[/tex]
Multiply by [itex]a^3[/itex]: [itex]na^3= (a^3)^2+ \left(\frac{m}{3}\right)^3[/itex] or [itex](a^3)^2- na^3+ \left(\frac{m}{3}\right)^3= 0[/itex].
We can think of that as a quadratic equation in [itex]a^3[/itex] and, by the quadratic formula
[tex]a^3= \frac{n\pm\sqrt{n^2- 4\left(\frac{m}{3}\right)^3}}{2}= \frac{n}{2}\pm\sqrt{\left(\frac{n}{2}\right)^2- \left(\frac{m}{3}\right)^2}[/tex]
From [tex]a^3+ b^3= n[/tex]
[tex]b^3= n- a^3= n- \frac{n}{2}\pm\sqrt{\left(\frac{n}{2}\right)^2- \left(\frac{m}{3}\right)^2}=\frac{n}{2}\mp\sqrt{\left(\frac{n}{2}\right)^2- \left(\frac{m}{3}\right)^2} [/tex]
Take cube roots to find a and b and then x= a+ b. There are, of course, three cube roots for each so 9 possible combinations but some add to give the same x.
Likes PcumP_Ravenclaw and mfb
Halls' nice explanation is similar to that in the classic text of Euler, pages 262-271, where you may also find several worked examples and some problems. On page 272 ff. he also explains the more complicated case of a quartic.
https://archive.org/details/elementsofalgebr00eule
Likes jim mcnamara
Hello,
Thank you for reaching out and expressing your interest in understanding Cardano's method for solving cubic equations. I will try my best to explain the concepts and answer your questions.
Firstly, it is important to note that Cardano's method is one of the methods used to solve cubic equations. It is named after the Italian mathematician Gerolamo Cardano who first published it in his book "Ars Magna" in 1545. The method involves making a series of substitutions and manipulations to transform the original cubic equation into a simpler form that can be solved using known methods.
Now, let's address your questions one by one.
1. The two substitutions you mentioned, ## P1(z - a/3)## and ##P(z - b/z) ##, are indeed part of the process in Cardano's method. The first substitution is used to eliminate the quadratic term in the original cubic equation (##z^3 + az^2 + bz + c = 0##) and the second substitution is used to eliminate the cubic term. This results in the equation you mentioned, ##z^6 - cz^3 - b^3 = 0##, which can then be simplified further.
2. You are correct in saying that the solutions for ##z## in the equation ## z^3 = y1## or ##y2 ## are only two, namely 2 and -2. However, when we substitute these values back into the original cubic equation, we get three distinct solutions for ##z##, as you can see in the paragraph from the text. This is because the other solutions for ##z## (from ##z^6 - cz^3 - b^3 = 0##) are complex numbers, and when we take their cube root, we get three distinct solutions.
3. The variables ##v## and ##v1## are introduced in the text to represent the roots of the equation ##z^6 - cz^3 - b^3 = 0##. This is a result of the substitution ##P(z - b/z) ##, which leads to a quadratic equation in terms of ##z^3##. The roots of this quadratic equation are ##v## and ##v1##, and as you can see, they are related by ##v1 = -b/v##.
4. The coefficients, a, b, and c, in the equation 3.6.1 of
Related to Understanding Cardano's method of solving Cubic equation
1. What is Cardano's method of solving cubic equations?
Cardano's method is a solution for finding the roots of a cubic equation, where the highest degree of the equation is three. It was developed by Italian mathematician Gerolamo Cardano in the 16th century and is based on the use of complex numbers and radicals.
2. How does Cardano's method work?
The first step in Cardano's method is to reduce the original cubic equation to a simpler form by substituting a new variable. Then, the equation is solved using a combination of arithmetic operations and the use of complex numbers and radicals. Finally, the roots of the original equation are found by back-substituting the value of the new variable.
3. What are the advantages of Cardano's method?
Cardano's method allows for the solution of cubic equations with real coefficients, even when the solutions are complex numbers. It also provides a systematic approach to solving cubic equations, making it easier to follow and understand compared to other methods.
4. What are some limitations of Cardano's method?
One limitation of Cardano's method is that it can only be used to solve cubic equations, and cannot be applied to equations with higher degrees. Additionally, the computations involved in the method can be complex and time-consuming.
5. How important is Cardano's method in mathematics?
Cardano's method is considered a significant advancement in mathematics, as it provided a systematic approach to solving cubic equations and paved the way for the development of other methods for solving higher degree equations. It also introduced the use of complex numbers and radicals in the solution of equations, which has become a fundamental concept in mathematics.
