futurebird
- 272
The Cauchy Integral Theorem says that given f(z), an analytic function in a simply connected domain D and C, a Jordan curve contained in D:
[tex]\int_{C}^{}f(z)dz=0[/tex]
The words "simply connected" are important because if the closed contour encloses points where the function is not analytic it may have a value other than zero.
There are a few things that confuse me here:
- Is a branch point always a point where the function is not analytic?
- Is a point where the function is undefined, that is not a branch point always a point where the function is not analytic?
- Intuitively, why should the integral be zero? Is it because the line integral of a complex function is summing up direction vectors at every point in the curve, and when you return to where you started on a closed curve you have essentially "not moved" so the sum of the direction vectors is zero?
- When a closed contour's integral has a value other than zero, is this ever related to the fact that you went over a branch cut? If not why will this happen?
