Understanding colors (Lights And Optics)
  • Thread starter zzoo4
  • Tags
    Optics
In summary, light is characterized by its frequency and different colors have different frequencies. The color of an object is determined by the frequencies of light it reflects or absorbs. Our perception of color is based on the response of cone cells in our eyes to these frequencies. Mixing light is different from mixing pigments, as it follows the principles of additive color. White light contains all visible frequencies and darkness is the absence of light. The visible spectrum is a continuous band of frequencies, with each color corresponding to a unique frequency.
zzoo4
42
Well, This isn't a homework , but today in class we talked about how lights shining on a object produce different color. But I do not know what color it produces??
I know that Primary colors of light are red green and blue. Secondary are magenta and cyan and yellow.
If we have a red cherry on the desk and we shine yellow light, Why does it produce or reflect red?? Teacher said it reflects green but how?
And vice versa if we shine a red light into a yellow banana, we get red
and if we shine blue, we get black.. why??
Can someone help me understand why these colors are produced and how i can tell??
light itself isn't organized as primary and secondary colors that is a result of your eyes ability to see color. You have three types of receptors:
http://en.wikipedia.org/wiki/Young–Helmholtz_theory
light itself is characterized by its frequency red light has a lower frequency than green or blue light.
the banana is yellow because it reflects that frequency and absorbs the other visible ones. as bananas age they go from green to yellow to brown (reddish) so its seems it would have a varying ability to reflect these colors but not blue and that's why you see black.
But what if you don't know the frequency. But just the color...
White light is composed of all of the frequencies in the visible portion of the electromagnetic spectrum. This means that all of the colors have a unique and corresponding frequency. Darkness is just the absence of light.
Whenever you "see" a color, this is the result of light frequencies being added together starting with darkness. This is called additive color.
Mixing light is not the same process as mixing pigments such as paint, crayons, or other dyes. Those "colors" are produced in a process called subtractive color in which the frequencies of light are subtracted from each other starting with white light.
The components in our body responsible for the perception of color vision are the cone cells located in the retina of our eyes and different cells respond to different frequencies of light.
So as jedishrfu has stated, when you perceive a that an object has color, it's because that the object absorbs all of the frequencies except for the ones that your photoreceptors respond to. Each color has a corresponding frequency; Theoretically, there are an infinite amount frequencies, therefore just as many colors. This is why the collection of colors is called a visible spectrum; It is a continuous band of frequencies. You can't separate a color from its frequency; The color is represented by it.
I can explain the phenomenon of colors in terms of the physics of light and optics. The colors we see are a result of how light interacts with objects and how our eyes perceive that interaction.
First, it is important to understand that light is made up of different wavelengths, each corresponding to a different color. The primary colors of light, as you mentioned, are red, green, and blue. These colors are called additive primary colors because they can be combined to produce other colors. For example, if we combine red and green light, we get yellow light.
Now, when light shines on an object, the object absorbs some wavelengths of light and reflects others. The wavelengths that are reflected determine the color of the object that we see. In your example of a red cherry under yellow light, the cherry appears red because it absorbs all the wavelengths of light except for red, which is then reflected back to our eyes. This is why the cherry appears red under any light source, because it always reflects red light.
Similarly, a yellow banana appears yellow because it reflects yellow light and absorbs all other wavelengths. When we shine a red light on the banana, it appears red because the red light is the only light that is being reflected back to our eyes. When we shine blue light on the banana, it appears black because the blue light is being absorbed and no light is being reflected back to our eyes.
In summary, the colors we see are a result of the interactions between light and objects. The colors that are produced depend on the wavelengths of light that are reflected by the object. I hope this helps you better understand the concept of colors in lights and optics.
Related to Understanding colors (Lights And Optics)
1. What is the difference between additive and subtractive colors?
Additive colors are created by combining different wavelengths of light, such as red, green, and blue, and result in white light. Subtractive colors are created by absorbing certain wavelengths of light, such as cyan, magenta, and yellow, and result in black when combined.
2. How does the human eye perceive color?
The human eye contains specialized cells called cones that are sensitive to different wavelengths of light. There are three types of cones, each responding to either red, green, or blue light. The brain combines these signals to create the perception of color.
3. What is the role of light in color perception?
Light is necessary for us to see colors. When light hits an object, some wavelengths are absorbed and others are reflected. The reflected wavelengths are what our eyes detect and interpret as color.
4. How do objects appear to have different colors?
The color of an object is determined by the wavelengths of light that it reflects. For example, an object may appear red because it reflects mostly red light and absorbs other wavelengths. The color also depends on the light source and the properties of the object's surface, such as texture and glossiness.
5. Can colors affect our emotions and behavior?
Research has shown that colors can have an impact on our emotions and behavior. For example, warm colors like red and orange can evoke feelings of energy and excitement, while cool colors like blue and green can have a calming effect. However, the perception of color can also be influenced by cultural and personal experiences.
  • Classical Physics
  • Electrical Engineering
  • Other Physics Topics
