Understanding Corollary 6.2.2 of B&S Theorem 6.2.1
In summary: Specifically, continuity is a key assumption for the application of Rolle's theorem and the mean value theorem, two of the most important tools in analysis. In fact, the corollary in question essentially states that if the derivative of a continuous function at a point is zero (or nonexistent), then that point is a candidate for a local extremum. This is often used in conjunction with Rolle's theorem to find the exact location of the extremum. Furthermore, the assumption of continuity is necessary in order to guarantee the existence of a local extremum at a point. Without it, there are examples of functions that have a relative extremum at a point
Math Amateur
MHB
3,998
48
I am reading "Introduction to Real Analysis" (Fourth Edition) by Robert G Bartle and Donald R Sherbert ...
I am focused on Chapter 6: Differentiation ...
I need help in fully understanding the corollary to Theorem 6.2.1 ...Theorem 6.2.1 and its corollary ... ... read as follows:
Can someone please demonstrate how to prove Corollary 6.2.2 above ...Note that ... obviously ... if the derivative of \(\displaystyle f\) exists then since \(\displaystyle c\) is an interior point at which \(\displaystyle f\) has a relative extremum then \(\displaystyle f'(c) = 0\) by Theorem 6.2.1 ... maybe this forms part of the proof ...
Hope someone can help ...
Peter
Hi Peter,
Either the derivative of $f$ at $x=c$ exists or it doesn't, and these are the only two possibilities. If it does, then $f'(c)=0$ from the theorem.
GJA said:
Hi Peter,
Thanks GJA ...
Just another question ... why does f need to be continuous ...?
Peter
Hi Peter,
I don't see the need for assuming continuity. Just like the theorem statement, all you really need is the knowledge that $f$ has a local extremum at $x=c$.
GJA said:
Hi Peter,
Thanks GJA ...
Now ... just to be very clear ... you are saying that Bartle and Sherbert have put an irrelevant/unnecessary assumption in the corollary to the Interior Extremum Theorem ... Is that correct?
Peter*** EDIT ***
To add to my perplexity I have just discovered a similar corollary to the Interior Extremum Theorem in Manfred Stoll's book "Introduction to Real Analysis ... in the corollary, Stoll characterizes f as continuous on a closed interval ... whereas Bartle and Sherbert define f as continuous on an interval I ... ...
The theorem and its corollary in Stoll read as follows:View attachment 7297Since continuity is stated as an assumption in both Bartle and Sherbert and Stoll, it seems we should at least take it seriously ... are you sure your proof (that does not appear to need continuity) is valid ...
Note that I have to confess that I cannot fault your proof ...!?
Hi Peter,
I'm saying I don't see the value of the continuity assumption based on what you've shared. Perhaps the authors had a specific reason for including it, and, if they did, it's unclear to me what that purpose was.
Edit: I could speculate a reason or two, but as far as "proving" the corollary it appears superficial because the theorem statement is stated in a more general form (and thus subsumes the corollary).
Hi Peter,
Since Stoll uses a closed bounded (i.e., compact) interval, a global maximum and minimum (which are a fortiori local maximums and minimums, respectively) are guaranteed to exist since $f$ is assumed continuous. Bartle and Sherbert don't specify an interval type for $I$, so they must assume the existence of a local extremum (e.g., $f(x) = x$ has no local extrema on $(0,1)$).
If I had to speculate as to why both sets of authors choose to include the continuity assumption, I would guess that they are attempting to provide the reader with a tool (the corollary) that finds wide use in applications/examples. What do I mean here? Suppose you are working on a mathematically formalized problem that involves a continuous function on a compact (i.e., closed and bounded) interval $[a,b]$. Now in some cases simply knowing that this function possesses a global maximum and minimum on $[a,b]$ is all you need to know.
Sometimes, however, you may want to know the precise locations (i.e. the "exact" values for $x$ - exact in quotes because in practice one usually must numerically approximate the values) for the local extrema of $f$ on $[a,b]$ (e.g., perhaps $f$ represents the force exerted on a piece of wire, which is modeled by the interval $[a,b]$. Then one may be interested in knowing the point on the wire that experiences the greatest force). In this case, the theorem that guarantees the existence of these extrema is of little to no value to you, as there is nothing in the proof of that theorem that tells you how to actually locate the extrema you know to exist. This is where the corollary comes in. It says that if you need to know the "exact" location of the function's extrema, then you should find the values of $x$ where $f'(x)$ is zero and fails to exist. One must take care, however, to note that not every point one finds in this manner corresponds to a local extremum (i.e., the converse of the corollary is not true: e.g., $f(x)=\sqrt[3]{x}$ on $[-1,1]$ does not have a local extremum at $x=0$, even though $f'(0)$ DNE; similarly, $f(x)=x^{3}$ does not possesses a local extremum at $x=0$, even though $f'(0)=0$). Nevertheless, the values you determine by using this process are the candidates for the extrema you choose to hold dear on the problem you're solving. Stoll's remark after the corollary tries to warn you what can happen if the desired extrema sits at an endpoint of $[a,b]$ instead of interior to it (as is assumed in the corollary's statement). I must reiterate, though, that this is only my guess as to why they are formulating things this way.
Note that I have to confess that I cannot fault your proof...!?
I assure you that your curiosity and genuine desire to understand are never met with even the slightest indignation.
GJA said:
Hi Peter,
Thanks GJA ...
I really appreciate your helpful and thoughtful analysis ...
Thanks again,
Peter
Peter said:
Thanks GJA ...
Peter
Suppose that the word continuous is not mentioned ,and let us examine whether f is continuous at c or not.
Case I : f is not continuous at c. But we know that differentiability implies continuity and by contrapositive law : not continuity implies not differentiability.
Hence the derivative at c does not exist
Case II : f is continuous at c,then by the law of excleded middle the derivative at c exists or does not exist.
If it exists by the previous theorem : f'(c)=0
If it does not exist there is nothing to be examined.
Hence whether the function is continuous or not ,by using the law proof by cases of logic the derivative at c either does not exist or f'(c)=0
Hence if the Author does not mention the word continuous in his hypothesis the result is the same with the case where the Author mention the word continuous in his hypothesis. .
However the word continuous in the hypothesis does not participate in the 100% correct proof given by GJA
FAQ: Understanding Corollary 6.2.2 of B&S Theorem 6.2.1
What is Corollary 6.2.2 of B&S Theorem 6.2.1?
Corollary 6.2.2 of B&S Theorem 6.2.1 states that if two angles of a triangle are congruent to two angles of another triangle, then the triangles are similar.
How is Corollary 6.2.2 related to B&S Theorem 6.2.1?
Corollary 6.2.2 is a direct consequence of B&S Theorem 6.2.1, which states that if two triangles have two pairs of congruent angles, then the triangles are similar.
Why is Corollary 6.2.2 important?
Corollary 6.2.2 is important because it allows us to prove the similarity of triangles in a simple and efficient way. It is also a fundamental concept in geometry and is used in many geometric proofs and constructions.
How can Corollary 6.2.2 be applied in real life?
Corollary 6.2.2 can be applied in real life situations where we need to determine if two objects or structures are similar. For example, it can be used in architecture to ensure that two buildings have the same proportions or in engineering to create scaled models of larger structures.
Are there any exceptions to Corollary 6.2.2?
Yes, there are exceptions to Corollary 6.2.2. If the two angles of a triangle are congruent to two angles of another triangle, but the sides opposite those angles are not proportional, then the triangles are not similar. This is known as the AAA (Angle-Angle-Angle) similarity postulate.
