Understanding CSM Displacement with Offset
  • Automotive
  • Thread starter Jason Louison
  • Tags
    Displacement
In summary, the maximum and minimum displacement occur when the angle of the crank is equal to 22.02 degrees.
Jason Louison
70
So I know that the relationship between the crank throw and the stroke of a non-offset CSM is S=2R. But then I realized that when offset is introduced, the stroke length changes just a little. So I spend some time drawing diagrams and then found out that the maximum piston position for any CSM is at the angle formed by the offset @ 0 degrees CA, and minimum is just 180 degrees plus that. For example, a CSM has a Connecting Rod length of 4 and an offset of 1.5. Doing some math, we come up with Angle=Sin^-1(d/L), where L is connecting Rod length and d is offset. Our answer is approximately 22.02 degrees, and thus when the angle of the crank is 22.02 or 202.02 degrees, maximum and minimum displacement occur. Let's say this mechanism has a crank throw (radius) of 2. The equation I came up with so far is S=2R(1/cos(Z)), where S is the stroke length, R is the radius, and Z is the angle formed by the offset. Plugging in our variables, we get: S = approximately 4.315 units, but when I check it by using actual displacement functions, it differs by just a little bit!: S = 4.330. Does anyone know why this occurs?
Displacement Equation: D=Rcos(X)+sqrt(L^2-(Rsin(X)-d)^2)
Where X is crank angle.
The stroke is simply the distance between the extreme positions. Determining this does not require anything more than some triangle solutions. The max distance from crank to wrist pin happens when the crank and connecting rod are aligned. The min distance occurs when they are again aligned but now overlapping.
Yes, but I was thinking in terms using a formula for a spreadsheet.
So, what is the difficulty?
I was thinking that there must be some sort of relationship between The crank radius and stroke, even with offset
Let R = crank radius, L = connecting rod length, and e = offset. Further, let X = wrist pin distance from the crank axis. Then
(L + R)^2 = e^2 + Xmax^2 Pythagoras at full extension
(L - R)^2 = e^2 + Xmin^2 Pythagoras at minimum extension
Solve these for Xmax and Xmin, then take the difference to get
stroke = S = Xmax - Xmin
You can do the algebra to roll all this into a single expression.
Likes Jason Louison
Thanks man!
Related to Understanding CSM Displacement with Offset
1. What is CSM displacement with offset?
CSM displacement with offset is a measurement technique used in geophysics to determine the depth of subsurface structures. It involves measuring the travel time of seismic waves that have been reflected off of underground layers and calculating the distance between the source of the waves and the point of reflection.
2. How does CSM displacement with offset work?
CSM displacement with offset works by using a seismic source, such as a controlled explosion or a mechanical vibrator, to generate waves that travel through the subsurface. These waves are then reflected off of underground layers and detected by sensors called geophones. The travel time of the waves is measured and used to calculate the depth of the subsurface structures.
3. What are the benefits of using CSM displacement with offset?
CSM displacement with offset is a non-invasive and cost-effective method of determining subsurface structures. It allows for accurate measurements of depth and can provide valuable information for geological and engineering projects, such as oil and gas exploration, mineral exploration, and construction planning.
4. Are there any limitations to CSM displacement with offset?
One limitation of CSM displacement with offset is that it is most effective in areas with relatively flat subsurface layers. In areas with complex geological structures, the results may be less accurate. Additionally, this technique may not be suitable for very deep subsurface structures.
5. How is CSM displacement with offset different from other geophysical techniques?
CSM displacement with offset is one of several geophysical techniques used to study the subsurface. What sets it apart is that it measures the travel time of seismic waves rather than their amplitude. This allows for more accurate depth measurements and is particularly useful for identifying subtle changes in subsurface structures.
9K
  • Classical Physics
