Understanding Cubic Factorization: Solving for Roots with a and -2a
In summary, "Understanding Cubic Factorization: Solving for Roots with a and -2a" explores the process of factoring cubic equations by identifying roots based on parameters a and -2a. The article emphasizes the importance of recognizing the relationship between coefficients and roots in cubic functions, and it provides methods for deriving the factors using algebraic techniques. Through examples, it illustrates how to simplify the factorization process and find real roots effectively.
Argonaut
45
24
Find the roots of the following equation:
$$x^3-3a^2x+2a^3=0$$
where ##a## is a constant.
None
This is part of a longer exercise I struggled with. I checked the solutions manual, and there was a bit where they performed the following steps:
$$x^3=3a^2x-2a^3 \\$$
$$(x-a)^2(x+2a)=0$$
And then concluded that the roots were ##a## and ##-2a##, which is clear. What I can't work out is how they factorised the original equation.
I've got as far as figuring out that ##a## is a root so that ##(x-a)## must be a factor, but I didn't get any further than that.
What am I missing?
Argonaut said:
Homework Statement: Find the roots of the following equation:
Relevant Equations: None
$$(x-a)^2(x+2a)=0$$
What am I missing?
The quick answer to this is a variation on the rational root theorem. First try ##x = \pm a, \pm 1## and see if there are solutions. If there is one, or more, then you can find the rest by doing a long division on the polynomial, and use the quadratic formula or just solve the linear equation. It turns out that you can easily find solutions to this cubic this way.
The long answer is Cardano's method. This is already a depressed cubic, so it shouldn't be too awful hard, but it is going to get a bit involved.
-Dan
Likes WWGD and Argonaut
$$(x-a)^2(x+2a)=0$$
What am I missing?
Write [tex]x^3 - 3a^2 x + 2a^3 = (x - a)(x^2 + Ax + B)[/tex] and expand the right hand side. Compare coefficients of powers of [itex]x[/itex] to find [itex]A[/itex] and [itex]B[/itex]. Or use [tex]
(x - a)^3 = x^3 - 3ax^2 + 3a^2 x - a^3[/tex] to write [tex]
\begin{split}
x^3 - 3a^2 x + 2a^3 &= \left((x - a)^3 + 3ax^2 - 3a^2 x + a^3\right) - 3a^2 x + 2a^3 \\
&= (x - a)^3 + 3ax^2 - 6a^2 x + 3a^3\end{split}[/tex] and further simplify the final expression.
Likes Argonaut and topsquark
If you encounter such problems in artificial situations like homework, exams, or examples in books, then it is almost always the case that one solution can be guessed. We see in our case that ##x=a## is a zero of ##x^3-3a^2x+2a^3.## This means that ##(x-a)## divides the polynomial ##x^3-3a^2x+2a^3.## You can perform a long division like you do with numbers
(x^3-3a^2x+2a^3) \, : \,(x-a) = q(x)
to receive the resulting polynomial ##q(x)## which has to be of degree ##2## and ##q(x)=0## can be solved by e.g. completing the square, or solve the equation
q(x)\cdot (x-a)=(x^2+Ax+B)\cdot (x-a)=x^3-3a^2x+2a^3
as @pasmith suggested. Both works. I like the long division because it is only one step and I need the practice for more complicated cases, but that is a matter of taste (and the degree of the polynomials).
If we have ##q(x)=x^2+ax-2a^2## then we see that ##x=a## is another zero and we can divide again by ##(x-a)## or use the known formula
q(x)=0\Longrightarrow x_{1,2}=-\dfrac{a}{2}\pm \sqrt{\dfrac{a^2}{4}+2a^2}=-\dfrac{a}{2}\pm \dfrac{3}{2}a\Longrightarrow x\in \left\{a\, , \,-2a\right\}
And ##x^3-3a^2x+2a^3=(x-a)\cdot (x-a) \cdot (x-(-2a))=(x-a)^2(x+2a).##
Thanks, @topsquark, @pasmith and @fresh_42, for the insightful replies. I'm much obliged!
I now realise that the long division of polynomials has been a glaring blind spot in my mathematical repertoire.
(An amusing aside:
I blame the inconsistency of mathematical notation across nations! :biggrin:
You see, as a pupil, I was taught long division using the German method. However, I only learnt the long division of polynomials much later and using the 'English method', and the whole thing felt cumbersome because of the new notation. I didn't realise they were the same algorithm, just different notation. I drilled the English method with polynomials for a while, but it quickly fell out of my mathematical toolbox, because I still tend to reach for the German long division whenever needed. Now I know I can use the familiar and comfortable German method to carry out the long division of polynomials. It seems like a silly oversight.)
Likes topsquark
Likes fresh_42
FAQ: Understanding Cubic Factorization: Solving for Roots with a and -2a
What is cubic factorization?
Cubic factorization is the process of breaking down a cubic polynomial (a polynomial of degree three) into simpler factors that, when multiplied together, give back the original polynomial. This often involves finding the roots of the polynomial and expressing it as a product of linear and/or quadratic factors.
How do you solve a cubic equation with roots a and -2a?
To solve a cubic equation with roots a and -2a, you start by expressing the polynomial in the form (x - a)(x + 2a)(x - r) = 0, where r is the third root. You then expand and simplify this product to obtain the cubic polynomial. Finally, you can solve for the unknowns by comparing coefficients or using methods like synthetic division or the Rational Root Theorem.
What methods can be used to find the roots of a cubic polynomial?
Several methods can be used to find the roots of a cubic polynomial, including factoring by grouping, using the Rational Root Theorem, synthetic division, and applying Cardano's formula. Graphical methods and numerical techniques like Newton's method can also be employed for approximations.
Can a cubic polynomial have complex roots?
Yes, a cubic polynomial can have complex roots. According to the Fundamental Theorem of Algebra, a cubic polynomial has three roots, which can be real or complex. If a polynomial has real coefficients, complex roots will occur in conjugate pairs. For example, if a + bi is a root, then a - bi will also be a root.
What is the significance of the roots a and -2a in a cubic equation?
The roots a and -2a in a cubic equation indicate specific points where the polynomial equals zero. These roots are particularly interesting because they show a relationship between the roots (one being a multiple of the other). This relationship can simplify the factorization process and provide insights into the polynomial's symmetry and behavior.
34K
