Understanding Cubic Roots of 1: Exploring cis 120k
In summary: A great book for this is, "Pi and the AGM" by Jonathan and Peter Borwein.In summary, the discussion is about the roots of unity and the relationship between the cubic root of 1 and the complex number cis 120k k=0,1,2,... which is equivalent to the expression e^{2\pi ki} where k is an integer. The cubic root of 1 is not just 1, but also has two complex roots, which can be found by using the quadratic formula with a=1, b=1, and c=1. Similarly, the quarter root of 1 can be found by solving the equation x^4=1. In general, the n-th roots of unity
Yankel
395
Hello
I didn't know in which forum to put this...
I solved a linear algebra question, and my answer was:
{1}^{1/3}
which to my understanding is 1. In the book however, they said it is equal to cis 120k k=0,1,2,...
where 120 is degrees. I tried taking the complex number 1+0i and turn it into it's polar version but did not get 120 degrees. Can you explain to me why the cubic root of 1 is cis 120 ?
Mathematics news on Phys.org
Let's let:
\(\displaystyle x^3=1=e^{2\pi ki}\)
Hence:
\(\displaystyle x=e^{\frac{2}{3}\pi ki}=\text{cis}\left(\frac{2k}{3}\pi\right)\)
I see...
but why did they do it in the first place ?
Am I wrong that the cubic root of 1 is 1 ?
What about the quarter root of 1 ?
Yankel said:
I see...
If you restrict yourself to real roots, then $x=1$ is the only such real root. However, as I am sure you know, a cubic equation will have 3 roots, and since there is only 1 real root to the equation in question, we know there must be two complex roots, and we know further that they are conjugates.
The quarter or 4th root of 1 will satisfy:
\(\displaystyle x^4=1\)
You can solve this by factoring. In general we will find the $n$th roots of unity to be equally spaced about the unit circle in an Argand diagram, where \(\displaystyle \theta=\frac{2k\pi}{n}\) with $0\le k<n,\,k\in\mathbb{Z}$.
Yankel said:
I see...
You're not wrong, but you're not entirely right, either.
First, what do we MEAN by: "a cube root of 1"?
We mean some "number" $x$ such that: $x^3 = 1$. Clearly, 1 works, since: $1^3 = 1$.
Another way to phrase this is:
$x^3 - 1 = 0$
Now, $x^3 - 1 = (x - 1)(x^2 + x + 1)$.
Taking $x = 1$, we see the left factor is 0, so the whole product is 0.
But what if $x \neq 1$? Could it be possible that $x^2 + x + 1 = 0$?
Well, if we use the quadratic formula, with $a = b = c = 1$, we obtain:
$x = \dfrac{-1 \pm \sqrt{1^2 - 4(1)(1)}}{2} = \dfrac{-1 \pm \sqrt{-3}}{2}$
which can be written in the form:
$x = -\dfrac{1}{2} \pm i\dfrac{\sqrt{3}}{2}$.
Note that this is:
$x = \cos\left(\dfrac{2\pi}{3}\right) \pm i\sin\left(\dfrac{2\pi}{3}\right)$
in other words, in the complex plane the "other two cube roots of 1" lie at the angles:
1/3 around the circle, and 2/3 (-1/3) around the unit circle.
You can verify, by direct computation, that if:
$\omega = -\dfrac{1}{2} + i\dfrac{\sqrt{3}}{2}$
that $\omega^2 = \overline{\omega}$, and also that:
$x^2 + x + 1 = (x - \omega)(x - \omega^2)$
(remember, complex solutions to a REAL quadratic come in conjugate-pairs).
The situation is quite analogous for the polynomial:
$x^n - 1$
the roots are:
$\cos\left(\dfrac{2k\pi}{n}\right) + i\sin\left(\dfrac{2k\pi}{n}\right)$
for $k = 0,1,2,\dots,n$.
For $n = 4$ (the fourth roots of 1), we get:
for $k = 0,\ \cos(0) + i\sin(0) = 1 + i0 = 1$.
for $k = 1,\ \cos\left(\dfrac{\pi}{2}\right) + i\sin\left(\dfrac{\pi}{2}\right) = 0 + i1 = i$
for $k = 2,\ \cos(\pi) + i\sin(\pi) = -1 + i0 = -1$
for $k = 3.\ \cos\left(\dfrac{3\pi}{2}\right) + i\sin\left(\dfrac{3\pi}{2}\right) = 0 +i(-1) = -i$.
Indeed, we have: $x^4 + 1 = (x^2 + 1)(x^2 - 1) = (x + i)(x - i)(x + 1)(x - 1)$.
It turns out there is a DEEP connection between $n$-th roots of a number, and $\frac{1}{n}$-th of a circle. The geometrical reason for this is that complex multiplication is "part stretching" and "part rotating".
The circle is a profound mathematical object. I cannot stress this enough. In mathematics we have two "big ideas": the line, and the circle. The extrapolation of these two simple things, leads to a vast array of interesting structures.
FAQ: Understanding Cubic Roots of 1: Exploring cis 120k
What is the cubic root of 1?
The cubic root of 1 is 1.
What does cis 120k stand for?
Cis 120k is a mathematical notation for the complex number 1 + 0i, where i represents the imaginary unit.
How do you find the cubic root of 1?
The cubic root of 1 can be found by taking the number 1 and raising it to the power of 1/3, which is equivalent to taking the cube root of 1.
Why is understanding cubic roots of 1 important?
Understanding cubic roots of 1 is important because it is a fundamental concept in algebra and complex numbers. It is also used in various applications such as engineering, physics, and computer science.
What are some real-life examples of cubic roots of 1?
Real-life examples of cubic roots of 1 include the vibrations of a guitar string, the motion of a pendulum, and the solution to certain differential equations. It is also used in signal processing and digital communications.
