MHB Understanding D&F Example 2: R/I Bimodule on Page 366
  • Thread starter Thread starter Math Amateur
    Example Tensor
Math Amateur
MHB
I am reading Dummit and Foote Section 10.4: Tensor Products of Modules. I would appreciate some help in understanding Example 2 on page 366 concerning viewing the quotient ring $$R/I $$ as an $$ (R/I, R) $$-bimodule.
Example (2) D&F page 366 reads as follows:
"(2) Let I be an ideal (two sided) in the ring $$R$$. Then the quotient ring $$R/I $$ is an $$ (R/I, R) $$-bimodule. ... ... ...
Now for $$ R/I $$ to be a $$ (R/I, R) $$-bimodule we require that :
1. $$ R/I $$ is a left $$ R/I $$-module
2. $$ R/I $$ is a right $$ R $$-module
3. (a + I) ( (b+ I) r) = ( (a + I) (b+ I) ) r where a+I, b+I belong to R/I and r is in R.
I have problems with the meaning and rules governing operations on elements in 2 above, and a similar problem with the operations in 3.Consider now, $$ R/I $$ as a right $$ R $$-module
Following Dummit and Foote's definition of a module on page 337 (see attachment) and following the definition closely and carefully (and adjusting for a right module rather than a left module), for $$M = R/I$$ to be a right $$R$$-module we require
(1) $$ R/I $$to be an abelian group under the operation +, which is achieved under the normal definition of addition of cosets, visually:
$$ (a + I) + (b + I) = (a+b) + I $$
(2) an action of $$R$$ on $$ R/I $$ (that is a map $$ R/I \times R \to R/I $$) denoted by $$( a + I ) r $$ for all $$ (a + I) \in R/I \text{ and for all } r \in R $$ which satisfies:
(a) $$ ( a + I ) ( r + s) = (a + I) r + (a + I) s \text{ where } (a + I) \in R/I \text{ and } r, s \in R$$
... ... and so on for conditions (b), (c) and (d) - see D&F page 337 (see attachment)My question is as follows:
How do we interpret the action $$( a + I ) r $$ , and also how do we interpret, indeed form/calculate expressions like $$ (a + I) r $$ in expressions (a) above ... also actually in (b), (c), (d) as well
I would appreciate some help.
Peter
It is natural to set:
$(a + I)r = ar + I$
(since $I$ is a 2-sided ideal, $Ir = I$).
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
