Understanding Dirac Notation: A Simplified Explanation for Scientists
In summary, Dirac notation is a way to represent wave functions and operators using kets and bras. Operators act on kets in the same way as they would on normal wave functions. The complex conjugate of a ket is represented by a bra vector. The inner product of a bra and a ket is defined as the complex conjugate of the wave functions multiplied and integrated over all space. The Riesz representation theorem states that for each ket there is a unique corresponding bra, and vice versa. This antilinear bijection preserves distances between points. The norm on the bras defined by the inner product is consistent with the operator norm. Expressions in Dirac notation are defined to make it look like multiplication with an associative operation. However,
  • #36
ok so I've been re-reading my calculus, linear algebra, and matrix/vector books and I've come across two things that are tripping me up, vector calculus and differential equations. for vector calc the one thing that i wasnt sure about is how do you integrate/ differentiate the vectors, do you simply use the magnitude and then the new differentiated for is the direction or is there something else to do. for the differential equations i have been reading differential equations for dummies and it said all you really needed for a backround was the calculus one for dummies which i read (as well as calculus two fr dummies) however i got very confused very early while reading the book. the thing that i found the most strange was when the author was explaining how to find the integrating factor for the equation dy/dt +2y=4. basically he says to multiply by an unknown factor or equation so it would look something like, U(t)dy/dt+ 2U(t)y=4U(t). Then he says this "now you have to choose U(t) so that you can recognize the left side of the equation as the derivative of some expression. This way it can easily be integrated. Here's the key the left side of the previous equation looks very much like differentiation the product of U(t)y. so try to choose U(t) so that the left side of the equation is indeed the derivative of U(t)y. Doing so makes he integration easy.
Th derivative of U(t)y by t is: d[U(t)y]/dt=U(t)dy/dt+ dU(t)y/dt", this is the part that confused me number one maybe I am just not reading it correctly or i just completely missed something in calc but how is that the derivative of U(t)y. secondly the equation was 2U(t)y not U(t)y. then the next part that tripped me up was this "comparing the previous two equations term by term gives you: dU(t)/dt=2U(t). how did the two get back into the equation. These were just two parts that i got lost at and any help would be greatly appreciated.
  • #37
I bet you misread
[tex]\frac{dU(t)}{dt} y[/tex]​
or something similar.
You were computing the derivative of U(t)y. The differential equation you're trying to solve has nothing to do with that.
He's simply stating the thing he wants to be true: "the left hand side is equal to the derivative of U(t)y". (And then simplifying)
  • #38
ok for the first one i know that he specifically meant d[U(t)y]/dt only because the brakets were written in, but even if it was dU(t)/dt*y wouldn't it just be the derivative of U(t) times y and therefore not be the equation that he gave? (idk i am not too familiar with the d/dx notation I am more used to the F'(x) or y'). Then for the second thing, jwhat do you mean by the differential equation you're trying to solve has nothing to do with that. i guess i really didn't get what the purpose or goals of the differential equations is, like what is this problem trying to do and how is it helping me. Then for the last part, what's the signifigance of the left hand side being equal to the derivative of U(t)y?
  • #39
I was referring to the bit that you wrote as dU(t)y/dt -- since you didn't specify, I assumed that was the part that was bothering you. What did you think the derivative of [U(t)y] -- the product of two functions in t -- should have been?
I mean you need to pay attention to what you're doing. Yes, the overall goal is to solve the differential equation. But in his search, the thing he is doing right now is trying to find the derivative of [U(t)y] -- and the differential equation has absolutely nothing to do with that task.
That should be made clear by the next step he does after all of this.
Think back to when you learned how to solve quadratic equations -- in particular, the method of "completing the square". The difficulty in solving ax²+bx+c=0 a quadratic equation is that you have two terms involving x. One method of solution is to find a way to rearrange the equation to combine those terms into one, into the form "the square of something involving x equals something not involving x", which you know how to solve.
Your professor is about to pull a very similar trick here. He's looking for a way to combine both of the terms involving y into a single term, putting the equation into the form "the derivative of something involving y equals something that doesn't involve y".
  • #40
well for the derivative part i just thought about it as it being the derivative of U(t) and then the y would just be treated as a constant since it has no "t" terms. So i guess it was/is the derivative part that i found screwy. Also, i get what you are saying about the other two things now (i think :D), and its not a professor its the book called "Differential Equations for Dummies" and its by Steve holtzer ( i think).
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Science and Math Textbooks
  • Quantum Physics
11K
  • Quantum Physics
