- #36
Mentz114
- 5,432
- 292
Well I wouldn't want to 'refract' so I'll try to answer your original questions.bill cosby said:Would you care to answer my questions with at least a minimal amount of detail?
Can you delve with me into the actual fact - or at least interpretation - of [QM] science -or must we both remain astray in the land of rhetoric?
I’ll leave it up to your next post to educate, or to refract.
I presume it will be the latter, as you do not appear to hold any true communicable knowledge besides, "trust me."
I think the idea is that you spray the slits with bullets. The ones that go through the slits don't make interference bands. The ones that don't go through are irrelevant.bill cosby said:I seem to understand what's going on with the slit experiment, although what was the purpose of that machine gun example? Is the electron gun alway swung around drunkenly like that? I'm thinking that was just some type of transitional illustration to get people ready for the wave description.
We can ignore quanta that don't get to the screen behind the slits.I'm not sure I'm clear on exactly why the quantum is supposed to go through either slit, as in, doesn't it bounce around the "box" before eventually making it's way through the slits if it is aimed directly at the center between the slits?
No. The idea is that the quanta go through the slits, not tunnel through the barrier.Does quantum tunneling come into play here?
No. Electrons don't split. A particle can't become a 'pair'. As I said, not necessary or correct.How about some type of wavefront compression or field that causes the quanta of energy to split apart into antipairs before going through both slits and coming back on the other side. Can a normal quantum collide with a virtual particle?
Hmmm. I'm tempted...That probably doesn't even make sense.
