Understanding Dual Output Zener PSU
In summary: DC to DC converter to produce +- 15V with no transformer neededIn summary, the conversation discusses the voltages present in a circuit and how they are affected by various components such as a transformer, bridge rectifier, zener diodes, and resistors. The bottom rail is able to be negative due to the two zener diodes acting as a voltage divider. The circuit also has a cross-regulation problem and it is suggested to use other methods, such as a centre tapped transformer or voltage regulators, to produce a dual rail PSU.
Mzzed
67
I am struggling to understand the voltages present in the circuit below. So as stated in the diagram, there is 30V AC at the secondary of the transformer, this is equivalent of 42.4Vpeak. The bridge rectifier changes this to DC and drops the voltage down to roughly 26.3Vpeak DC where each diode is assumed to have 0.7V drop. The zener voltage is 15V so there must be a 11.3V drop across R1 and R2 total. Then ground is indicated as seen on the far right, so there must be a 15V drop across the zener diode ZD1. ZD2 also has a zener voltage of 15v so the bottom output is -15V meaning there is a 15V drop across that zener diode as well... Adding up the total voltage drop across the circuit, that would be 45V... from a 42.4Vpeak source voltage.
How is the bottom rail able to be negative? and why does it seem like there is a 45V drop across the circuit where the supply is only 42.4Vpeak AC (30V RMS)?
because you have forgotten that the smoothing cap increases the DC voltage
lets take out the zeners for a moment
your Vsec = 30V - 1.4Vthrough 2 diodes = 28.6VDC
28.6V x 1.414 ( the effect of the capacitor) = 40.44VDC OPEN CIRCUIT voltage
40.44V - ( little drops through the 2 resistors) = maybe ~ 38V ( you can do the math)
Now the above is with the secondary voltage on the diagram ... if the voltage is higher, then the sec voltage must be a bit higher
because the 2 zeners are acting like a voltage divider
with the central point 0V relative to the top or bottom rails ... as shown
if you put you meter negative lead on the centre of the 2 zeners and the positive of the meter to the top rail, you will read a + V
if you put you meter negative lead on the centre of the 2 zeners and the positive of the meter to the bottom rail, you will read a - Vjust a basic explanation :smile:
Dave
Likes Mzzed
Thankyou!
By converting to units in Vpeak form I was considering the capacitor by multiplying the 30Vrms by SQRT(2) or ~1.41, the capacitor will just bring Vrms up to this peak voltage. But i think all those specific voltages will fall into place once I understand why there is able to be a negative voltage after the two zener diodes.
Just to help me wrap my head around this, I'd like to think of an example where each zener diode is replaced with a resistor of some random value.
what would the bottom rail voltage be then? What determines where the ground is? is the bottom rail still negative? hahah sorry this confuses me quite a lot.
If the two zener diodes were replaced with two resistors of equal value, would they each have a 15V drop across each of them? (just not regulating at that voltage like a zener would do)
Remove the ground symbol from the schematic as I think it is confusing you. Then take another look. Work out the voltages and etc. Get your head wrapped around it. After that, reinsert the ground symbol and ask yourself why that should change anything since there is no other reference to that symbol on the schematic.
Likes Mzzed
yes, exactly ... they are still a voltage divider :smile:
Likes Mzzed
Some quick thoughts (apologies if they have been mentioned already above -- I'm skimming):
  • There should be an output capacitor for each output rail. So add 2 more polar caps right at the outputs with respect to Ground
  • This circuit has a pretty bad "cross-regulation" problem. The output current loading on one of the two outputs will change the output voltage of the other output. That is generally a bad thing in power supply design.
  • A better way to get split supplies from a single positive DC source is to use a linear or DC-DC step-down regulator for the positive rail, and an inverting DC-DC converter for the negative rail. Since both of those voltage regulator circuits are effectively in parallel, there is much less of a cross-regulation issue.
Likes davenn and Mzzed
yes, agree with all Berkeman's comments
and added to that, which I was eventually going to comment on...
... current supply from the "average" zener is generally very low 100mA max, give or take a little (unless a high wattage zener)
... also as the load varies, so does the current drawn and therefore so does the voltage.
They are a very poor way to get a "fixed" voltage, specially if circuit conditions vary, and even a worse in the configuration shown aboveDave
Likes berkeman and Mzzed
@Mzzed
The best and most conventional way to produce a dual rail PSU is to use a centre tapped transformer, eg ...
you could then use the appropriate voltage regulators at the +- 35V outputs to regulate down to what you need
you could use linear regulators ... say 7812, 7912 ... 7815, 7915 etc eg ...
or you could use switching regulators which are much more efficient
https://m.eet.com/images/eetimages/powermanagementdesignline/2010/12/C0678-Figure5.gifDave
Related to Understanding Dual Output Zener PSU
1. What is a dual output Zener PSU?
A dual output Zener PSU (power supply unit) is a type of power supply that has two separate voltage outputs, with each output regulated by a Zener diode. This allows for two different voltage levels to be supplied simultaneously, making it useful for powering circuits with multiple voltage requirements.
2. How does a dual output Zener PSU work?
A dual output Zener PSU typically consists of a transformer, rectifier, filter capacitors, and two Zener diodes. The transformer converts the incoming AC voltage to a lower AC voltage, which is then rectified to DC by the rectifier. The output of the rectifier is then filtered by the capacitors and regulated by the Zener diodes, providing two separate and stable voltage outputs.
3. What are the advantages of using a dual output Zener PSU?
One of the main advantages of a dual output Zener PSU is its ability to provide two different voltage levels simultaneously, making it useful for circuits with multiple voltage requirements. It also offers a more compact and cost-effective solution compared to using two separate power supplies. Additionally, the use of Zener diodes for voltage regulation allows for a simple and efficient design.
4. How do I choose the right dual output Zener PSU for my application?
When choosing a dual output Zener PSU, you should consider the voltage and current requirements of your circuit, as well as the stability and accuracy of the voltage outputs. It is also important to ensure that the power supply can handle the total power consumption of your circuit. Additionally, factors such as efficiency, size, and cost should also be taken into consideration.
5. How can I troubleshoot issues with a dual output Zener PSU?
If you are experiencing issues with your dual output Zener PSU, you can troubleshoot by checking the input voltage, output voltage, and current levels using a multimeter. If the voltage levels are not within the specified range, it could indicate a faulty component or incorrect wiring. You can also check for any loose connections or damaged components. If the issue persists, it is recommended to consult a professional or replace the power supply.
  • Electrical Engineering
