Understanding E subscript R Notation in the Context of General Relativity
The discussion centers on the notation of e subscript r in Sean Carroll's "Spacetime and Geometry," where it is identified as a unit vector in the radial direction, often denoted as ##\hat r##. Participants clarify that this notation is specific to the context of gravitational interactions between masses and is not simply a constant in vector form. The conversation also touches on the importance of understanding vectors and the necessity of mastering special relativity before tackling general relativity. Additionally, there is a debate on whether the radial direction refers to the separation of masses or the unit vector in polar coordinates. Overall, the thread emphasizes the significance of grasping these concepts for a deeper understanding of general relativity.
robotkid786
It's not homework, it's a query about the book "spacetime and geometry"
F=GMm/r^2 e subscript r in brackets
All I know is that e subscript r must be a vector cos the book says so, but what does it mean, is it, a konstant in vector form? I'm confused by it (page one, chapter one spacetime and geometry by SeanCaroll)
Help is appreciated
Edit. Is vector r describing the curvature that takes place ?
It's the unit vector in the radial direction, also written ##\hat r##.
Likes robotkid786
robotkid786 said:
Homework Statement: It's not homework, it's a query about the book "spacetime and geometry"
Relevant Equations: F=GMm/r^2 e subscript r in brackets
Help is appreciated
That's Carroll's notation for a unit vector in the direction of separation of the masses. The more usual notation involves the position vectors of the two masses ##\vec r_1, \vec r_2##. In which case, the force on mass ##m_2## is:
$$\vec F_2 = \frac{Gm_1m_2}{|\vec r_1 - \vec r_2|^3}(\vec r_1 - \vec r_2)$$
That's not actually what Carroll means in this context.
If by radial direction you mean the direction of separation of masses M and m then ok, but if you mean the unit vector in polar, spherical or cylindrical coordinates, then you are not ok :D.
##e_r, e_\theta## are often used to denote unit vectors in the radial and tangential directions in polar coordinates. Likewise ##e_x## etc. in Cartesian. See e.g. https://www.chegg.com/homework-help...-z-r-right-rangle-unit-radial-vect-q114756124.
Per @PeroK, it seems that Sean Carroll is here, in effect, electing to take one of the masses as being at the origin.
It's actually his own slighty idiosynchratic notation. In any case, it's only the prelude and only the briefest summary of Newtonian gravity before he introduces the Einstein Field Equations.
So, does this mean. The hat notation is equivalent to the subscription notation here?
In which case, as above, the vector here being referred to is in reference to the circular distance between m and M?
Sorry if I'm getting it wrong. I havent even done vectors in my degree yet and I can hardly remember the topic either 🙃
If you haven't studied vectors yet, you are wasting your time with a graduate textbook on GR. Moreover, you cannot seriously learn GR until you have mastered SR.
The vector being referred is the unit vector in the direction of the line that connects the centers of the two masses.
If we consider a coordinate system in spherical or polar coordinates and we put its origin in mass M or the mass m, then the vector being referred is also the radial unit vector of the coordinate system.
Likes MatinSAR, robotkid786 and PeroK
Got you, thanks man
Don't cut the wings of possibly I have to admit overambitious young students.
