Understanding Feedback Control in Klystrons
The discussion centers on the behavior of klystrons when feedback is applied to their input, contrasting them with magnetrons, which operate solely as oscillators. It highlights the complexities of feedback in high-frequency tubes like klystrons, questioning how much feedback can be utilized before the device transitions from amplifier to oscillator. The conversation touches on the methods of reducing feedback amplitude in RF applications, noting that feedback control mechanisms are crucial for maintaining amplifier functionality. Additionally, it mentions the potential for any amplifier to become an oscillator with the right feedback configuration, particularly referencing reflex klystrons for oscillation purposes. The risks of oscillation when improving amplifier performance through feedback adjustments are also noted.
artis
I was puzzled when I thought about what happens to a klystron when it's output is fed back to it's input.
This doesn't apply to magnetrons because they cannot be driven like amplifiers so they are oscillators by definition.
I've dealt with audio amplifiers mostly and there almost always feedback is used whether positive or negative.
But I do not know how it is with high frequency tubes like klystrons , how much feedback you can use and still have an amplifier and when it becomes an oscillator that then resonates at some frequency determined by the geometry of the tube or it's cavities.
At lower frequencies in audio amplifiers for example feedback is decreased in amplitude by passing it through resistors and then fed back into the input stage. But I am not familiar with how feedback is decreased in amplitude in RF applications.
What are the feedback control mechanisms for a klystron or other RF tube for example?Another question I am thinking about is how one would couple a wire loop from a toroidal (or any other shaped core) to a waveguide?
Any amplifier can become an oscillator by arranging feedback with a loop gain of unity at only the required frequency. There are too many methods of adjusting the frequency to list.
If you want to make an oscillator from a klystron, select a reflex klystron.
Improving an amplifier, by adjusting the feedback, is fraught with a high probability of oscillation. The named oscillator eponyms, are failed amplifier designers.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
