Understanding Finite Quotient Groups: G/H with G=Z6 and H=(0,3)
In summary, we have a group G=Z6 and a normal subgroup H=(0,3). We are asked to list the elements of the quotient group G/H. After listing the elements, it is shown that H+3 is equivalent to H+0, as 3+3=0 in Z6. This demonstrates the idea of a quotient group, where the difference between elements is "divided" out and they are considered equivalent. In this case, since G has 6 elements and H has 2, the quotient group G/H has 3 elements. However, it is important to note that each coset of H may have multiple names, which can be seen in the example of H+3 and H+
onie mti
51
G is a group and H is a normal subgroup of G.
where G=Z6 and H=(0,3)
i was told to list the elements of G/H
I had:
H= H+0={0,3}
H+1={14}
H+2={2,5}
now they are saying H+3 is the same as H+0, how so?
I had:
H= H+0={0,3}
H+1={14}
H+2={2,5}
Yes. That is the idea of a quotient group.
The difference between 0 and 3 is "divided" out.
They are considered equivalent.
Alternatively, since G has 6 elements and we divide by a H with 2 elements, that means that G/H has 6/2=3 elements.
Let's just do the math:
What is $H+3$?
Well, $H+3 = \{g \in G: g = h+3, h \in H\}$
So we add 3 to every element of $H = \{0,3\}$.
Thus $H+3 = \{0+3,3+3\}$.
However, in $\Bbb Z_6$, we have $3+3 = 0$, because 6 is a multiple of 6.
Thus, $H+3 = \{3,0\} = \{0,3\} = H$ (since in sets, the order in which we list the elements doesn't matter).
Similarly, $H+4 = \{0+4,3+4\} = \{4,1\} = \{1,4\} = \{0+1,3+1\} = H+1$.
I think you can convince yourself that $H+5 = H+2$.
Thus, out of the 6 possible "conceivable" cosets we have, it turns out that:
$H = H+3$
$H+1 = H+4$
$H+2 = H+5$
so there are only 3 DISTINCT cosets, although each one of the 3 has "two different names".
This is something to be wary of with cosets: a coset $Hg$ can have many different $g$ that identify the same coset. So even if $g \neq g'$, it still might be that $Hg = Hg'$.
IN GENERAL, if $Ha = \{a,h_1a,\dots,h_na\}$, we have $n+1$ different "names" for the same coset:
$Ha = Ha_k$ where $a_k = h_ka$.
Another interesting fact (which turns out always to be true):
$\Bbb Z_6 = \{0,1,2,3,4,5\} = \{0,3\} \cup \{1,4\} \cup \{2,5\} = H \cup (H+1) \cup (H+2)$,
any group $G$ is a union of the distinct cosets of any subgroup $H$.
In plane geometry, a coset of a line $L$ through the origin, is a coset $(x_0,y_0) + L$, which is a line parallel to $L$ that goes through the point $(x_0,y_0)$. This new line (the coset) is often called "the translation of $L$ by $(x_0,y_0)$" which represents "how much we shift $L$".
By analogy, cosets $Hg$ are often (especially in the ABELIAN case) called (in this case right) translations of $H$ by $g$. In other words, we can think of $H+k$ as "shifting $H$ by $k$ units", and doing this, it is clear for $\Bbb Z_6$ and $H = \{0,3\}$ we only have 3 possible shifts:
The null shift (shift by 0)
Shift by 1 (or 4, or 7, or...)
Shift by 2 (or 5, or 8, or...)
before the cycle repeats itself. That's why $\Bbb Z_6$ is called "cyclic", and is best visualized as the 6 vertices of a regular polygon (this can be done explicitly if one takes:
$[k] \iff \cos(2\pi k/6) + i\sin(2\pi k/6)$
in the complex numbers, and uses complex multiplication, instead of addition mod 6. The above is an example of an ISOMORPHISM, something you will soon be reading very much about).
FAQ: Understanding Finite Quotient Groups: G/H with G=Z6 and H=(0,3)
What is a finite quotient group?
A finite quotient group is a type of mathematical structure that is used to describe the relationship between two groups. It is formed by taking a group and dividing it by a subgroup, resulting in a new group with a smaller number of elements.
What is the significance of G=Z6 and H=(0,3) in this context?
In this context, G=Z6 represents the group of integers modulo 6, which consists of the elements {0, 1, 2, 3, 4, 5}. H=(0,3) represents the subgroup of this group, which consists of the elements {0, 3}. This choice of G and H allows for a clear and simple example of a finite quotient group.
How is the quotient group G/H calculated?
The quotient group G/H is calculated by taking the elements of G and dividing them by the elements of H. This results in a new group with the possible elements {0H, 1H, 2H, 3H, 4H, 5H}, where H is the identity element of the group H.
What are the elements and operation of the quotient group G/H?
The elements of the quotient group G/H are the cosets, which are the individual sets of elements resulting from the division of G by H. The operation of the quotient group is defined by the operation of the original group G, where the elements in each coset are multiplied together.
How does understanding finite quotient groups relate to other areas of mathematics?
Understanding finite quotient groups is important in many areas of mathematics, including abstract algebra, number theory, and algebraic geometry. It is also used in cryptography and coding theory to study the properties of finite fields.
