Understanding fractional and higher dimensions
In summary: In each step after that, we take each line segment that is now part of the figure, and repeat the process.
PcumP_Ravenclaw
106
Halo,
I was reading about geometry from Tim Gowers book titled "A very brief introduction to mathematics". I came across fractional dimensions and the 4th dimension. The koch snowflake has dimension 1.2 yet he could comfortably drawn it on a 2d page (or is it complete?). Has not he just transformed the original "snowflake", scaled it, translated it, etc.. what does it have to do with dimensions? maybe, its like drawing a 3d structure on a 2d page? so this snowflake is not how it actually appears in the 1.2 dimension as drawn on 2d page? This just a extrapolation of the formulas in 1d, 2d & 3d? How do we prove such domensions exist in reality, if at all? So a 4d cube as being a cube inside a bigger cube is also for sake of visualization, like drawing a 3d cube on a 2d page?
Please confirm!
Danke.
Mathematics news on Phys.org
Fractional dimensions come out of the notion of measuring a coast line the length depends on how close you are.
https://en.wikipedia.org/wiki/Coastline_paradox
and this on fractal dimensions:
https://en.wikipedia.org/wiki/Fractal_dimension
You could compare it to how integers were extended into rational number and then rational into real with the notion of irrational...
And so Mandelbrot extended the notion of dimension into a fractal (aka fractional) dimension.
Likes PcumP_Ravenclaw
PcumP_Ravenclaw said:
Halo,
A line segment has dimension one. A rectangle has dimension two, but its perimeter is one-dimensional. The Koch snowflake, in contrast, is so intricate that its perimeter is unbounded, even though it has a finite area. For that reason, it is considered to be one of several kinds of space-filling curves. Another space-filling curve is the Sierpinski triangle.
These are certainly not space-filling curves in the classical sense.
You're right - I misspoke. If they were truly space-filling, their dimension wouldn't be less than 2.
wha
what is a space-filling curve?
jedishrfu said:
Notice you can draw the curve without picking up your pencil and basically cover an entire area ie every point in the area is a part of the curve
Since the curve has infinite length, I doubt that.
This is interesting though. Continuous functions are often introduced as "those curves that can be drawn without picking up the pencil." But I think this is not the right motivation for continuity. The curves that can be drawn without picking up the pencil are (according to me) rather the continuous functions of bounded variation. Those seem like a much better contender.
ii
Halo,
What do you mean by "reality"? This is, after all, mathematics, not physics.
Basically, yes. They are representations of a higher dimensional object in two dimensions.
Please confirm!
Danke.
No. There is no "original snowflake." There is no scaling or translation going on. Creating the Koch snowflake is an iterative process, that starts with an equilateral triangle. Let's say the triangle has sides of length 1. In the first step, each of the three sides is divided into thirds. The middle segment is deleted, and two segments whose length is equal to the deleted segment are attached to the gap formed by deleting the middle third.
Graphically, we're going from ___ to _/\_ for each side. This same process is applied to the other two sides of the original equilateral triangle. In this first step, the perimeter increased from 3 to 4. (We removed a segment of length 1/3 from each of the three sides, but added two segments of length 1/3 to each side, so each side increased from 1 to 4/3 units.) Also, in this step, the triangle went from three sides to a polygon made up of 12 segments.
In the next step, each of the 12 segments has its middle third removed, and replaced by two more segments, in the same way as described above. This is much easier to show graphically than to explain in words.
FAQ: Understanding fractional and higher dimensions
What is a fractional dimension?
A fractional dimension is a concept in mathematics and physics that describes the number of directions or degrees of freedom that are required to describe the properties of an object or space. It is a non-integer value that falls between two whole numbers, such as 1.5 or 2.7.
How are fractional dimensions different from integer dimensions?
Integer dimensions, such as 1D, 2D, or 3D, describe objects with specific physical properties and behaviors. Fractional dimensions, on the other hand, allow for more complex and abstract descriptions of objects that cannot be fully explained by traditional integer dimensions.
What are some real-life examples of fractional dimensions?
One example of a fractional dimension is the coastline of a country. Depending on the level of detail and measurement scale, the coastline can have a non-integer dimension between 1 and 2. Another example is fractal geometry, where objects have self-similar patterns at different scales and can have fractional dimensions.
How are fractional dimensions used in science and technology?
Fractional dimensions are used in various fields of science and technology, such as physics, mathematics, computer science, and engineering. They help describe complex systems and phenomena that cannot be fully understood using traditional integer dimensions. For example, fractional dimensions are used in chaos theory, fractal geometry, and the study of phase transitions.
Can humans visualize fractional dimensions?
It can be challenging for humans to visualize fractional dimensions because our perception is limited to three dimensions. However, we can use mathematical models and computer simulations to help us understand and visualize objects with fractional dimensions. Additionally, some artists use fractal geometry to create visual representations of objects with fractional dimensions.
10K
