Wannabeagenius
- 91
Hi All,
I'm trying to understand heat so I'm going to say what I understand and ask you to please tell me if I am correct. Thank you.
Radiative Heat - This is heat transferred in the form of electromagnetic radiation and does not need a medium. If in a vacuum, the radiation will travel through the vacuum unimpeded. If a medium, such as air, is present, the radiation may or may not interact with the medium. If it interacts, it will transfer some or all of this heat to the medium as it continues on its way.
Convection - Heat transferred by the movement of a medium. For example, if a fireplace is being used, the air gets heated up and a gust of wind could transfer this hot air from one room to another.
Conduction - There is a medium but it does not move. The heat from molecules is transferred from molecule to molecule across the medium. I think of a bucket brigade here.
With regard to climate we talk about Radiative heat, latent heat and sensible heat.
Radiative heat - Same as above
Latent heat - Heat that is absorbed or released due to a change of state. For example, ice to water and water to vapor.
Sensible heat - This is where I have a problem. Heat that is absorbed or released without a change of state. It involves a temperature increase or decrease. Now it seems that this is any type of heat transfer as long as there is not a change of state which means Radiative, conduction or convection but I'm sure this is incorrect. Climate textbooks talk about Radiative heat, latent heat and sensible heat and radiative heat is definitely different from sensible heat.
Thank you,
Bob
Thank you,
Bob
