I Understanding Landau Levels for 3D Fermionic Gas in Magnetic Field
Sunny Singh
TL;DR Summary
Need an explanation of dimensionality reduction in this case.
I am a beginning graduate student and I've been assigned a paper which uses landau levels for 3d fermionic gas in uniform background magnetic field. I am having trouble finding a proper source which deals with solution of dirac equation in such a case. With the two papers that i have found which talks about it, i am finding it difficult to understand the degeneracy of landau levels and the associated density of states when it comes to finding the integration measure. Can you please suggest me a source, either in a book or any research article which explains landau levels for 3d fermions in detail?
Which two papers have you read? Aren't there references to other papers or even textbooks?
This is the first one: https://arxiv.org/abs/0705.4275
and the second one: https://arxiv.org/abs/1812.08886The one book that i found which deals with this problem is: Quantum Electrodynamics by Akhiezer and Berestetskii.
But given that the problem statement seems so simple i thought this must have been dealt with in many more books or papers but even though some books have a paragraph or two on this, none of them discuss the structure of landau levels and density of states in the direction perpendicular to the Pz motion (constant B in z direction) except the book i mentioned above. I was hoping that someone here would have experience with the structure of landau levels in case of 3d fermions since most of landau level stuff online is on electrons confined in 2 dimensions in the context of solid state physics.
There's a relatively new book by Fuxiang Han which you can look at amazon.
I bought the problem book, while I needed also to buy the main text.
I am not sure it covers Landau levels of 3d fermions, but you can give it a look if your library has a copy.
Likes Sunny Singh
Thanks, i'll look into it.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
