Understanding Line in R^3 Parallel to XY-Plane: Help Needed
In summary, a line in R^3 is parallel to the xy-plane if its displacement vector has a z-component of 0. This means that the line will not be parallel to any of the axes, unless one of the components of the displacement vector is also 0. The parametric equation for this line will have a fixed x and y component, while the z component will vary with the parameter t.
kerrwilk
What does it mean if a line in R^3 is parallel to the xy-plane but not to any of the axes. I really don't know what this means in terms of how the parametric and symmetric equations of the line should look. Please help. Thanks.
Mathematics news on Phys.org
A line in R^3 can be described by a parametric equation of the form
[tex]\textbf{r}(t) = \textbf{r}_0+t\textbf{v},[/tex]
where [itex]\textbf{r}_0[/itex] is the position vector representing a point in [itex]\mathbb{R}^3[/itex], [itex]t[/itex] is a real number, and [itex]\textbf{v}[/itex] is a non-zero displacement vector indicating the direction of the line (and also its orientation: which way along the line is positive).
The condition for this line to be parallel to the xy-plane is that the z-component of [itex]\textbf{v}[/itex] is zero. That is, [itex]\textbf{v}[/itex] must be of the form (v1,v2,0), where v1 and v2 are fixed real numbers, not both 0. Suppose this is the case. If, and only if, v1 is 0, the line will be parallel to the y-axis. If, and only if, v2 is 0, the line will be parallel to the x-axis.
Thanks! That was a great explanation.
Related to Understanding Line in R^3 Parallel to XY-Plane: Help Needed
1. What is the definition of a line parallel to the XY-plane?
A line parallel to the XY-plane is a straight line that lies completely within the XY-plane and never intersects it.
2. How can I determine if a line is parallel to the XY-plane?
To determine if a line is parallel to the XY-plane, you can check if the line's direction vector has a z-component of 0. If the z-component is 0, then the line is parallel to the XY-plane.
3. How do I find the equation of a line parallel to the XY-plane?
If you know the coordinates of a point on the line and the direction vector of the line, you can use the parametric equation of a line to find the equation of a line parallel to the XY-plane. The equation will be in the form of x = x0 + at and y = y0 + bt, where x0 and y0 are the coordinates of the point on the line and a and b are the x and y components of the direction vector.
4. Can a line be parallel to both the XY-plane and the XZ-plane?
Yes, a line can be parallel to both the XY-plane and the XZ-plane. This means that the line lies completely within the Y-axis and never intersects the XZ-plane.
5. How does understanding lines in R^3 parallel to the XY-plane apply to real-world situations?
Understanding lines in R^3 parallel to the XY-plane is useful in many real-world situations, such as in engineering and construction. For example, when building a structure, it is important to ensure that certain lines are parallel to the XY-plane to ensure stability and proper alignment.
  • General Math
21K
  • General Math
  • General Math
  • General Math
