Understanding MASERs and their properties
  • A
  • Thread starter TheCanadian
  • Tags
    Properties
In summary, masers have a maximum suspected density of ##10^{10}## atoms/m##^3##, but the only real limit is that atomic collisions should not impede the emission process. Masing regions can be about a parsec long, but individual emission spots can vary and have a typical length on the order of parsecs. The physical meaning behind pulses shorter than a year in masers is not fully understood, but it may involve entangled quantum systems. Flux versus velocity graphs in masers show the observed flux density plotted against velocity, with the assumption that the "true" frequency is a given value and the measured frequencies are velocities due to the relativistic Doppler shift. To convert flux measurements from Jansky to watts
TheCanadian
367
I've been reading Elitzur although with a number of questions, some likely too obvious that they aren't spelled out in the literature based on my searching. To ensure I understand some key details of masers, I thought I'd ask a few (simple) questions if that's all right.
1. Is there a maximum suspected density for masing regions? The largest I've read about is ##10^{10}## atoms/m##^3##. But the only real limit as far as I can tell is that atomic collisions should be sufficiently low as to not impede the emission process (i.e. dipole interactions should be sufficiently weak). And furthermore, are these masing regions typically assumed to be homogeneous in density for any particular reason?
2. Is there a maximum length on masers? I have read they can be about a parsec long, but did not read anything regarding constraints on this length. Although I did read velocity coherence is a necessary condition for masers; and Elitzur says "observations show indeed that maser sources are comprised of many emission spots, each with its own well defined velocity." I'm sure they can vary, but do individual emission spots have a typical length (i.e. are they on the order of parsecs in length still)?
3. If masers can be on the order of light years long, what exactly is the physical meaning behind pulses that are shorter in temporal width than a year? How exactly do photons from the stimulated emission process combine such that the observed signals are less than the light-propagation time through the maser? This seems to be observed in other forms of coherent radiation where the inverted sample itself is a few metres long yet the observed pulse has a width of femtoseconds. I believe these are entangled quantum systems, and perhaps there is more going on than I am aware, but is there any physical meaning behind how these pulses are smaller than the light propagation time through the inverted sample? Does light propagation still occur as normal, just with the radiating photons interacting in such a way that the width of the pulse is decreased?
4. What is the exact meaning of flux versus velocity graphs? For example, Figure 2 in this paper shows the observed flux density and it is plotted against velocity. Does the author simply assume the "true" frequency is a given value and then use their measured frequencies as velocities based on simply applying a (relativistic) Doppler shift equation? But if that is the case, we are only assuming the masing region is traveling at those velocities in the line of sight to us, correct? It appears there is a systemic velocity so I am likely completely wrong...
5. I have seen a lot of flux measurements of masers in the literature be made in Jansky which has units of ## \frac {\text{W}}{\text{m}^2 \text{Hz}}##. To convert this to the more familiar unit of watts, is it fine to simply multiply the flux by the surface area of the observing radio telescope (e.g. https://www.parkes.atnf.csiro.au/observing/documentation/user_guide/pks_ug_2.html#The-RadioTelescope), and then integrate this over the frequencies measured based on the signal's spectrum?
Any answers you may know and/or references would be greatly appreciated.
Likes K. Doc Holiday
Astronomy news on Phys.org
You ask very insightful questions.
Related to Understanding MASERs and their properties
1. What is a MASER and how does it work?
A MASER (Microwave Amplification by Stimulated Emission of Radiation) is a device that produces coherent microwave radiation. It works by amplifying the stimulated emission of photons from excited molecules in a resonant cavity.
2. What are the properties of a MASER?
The properties of a MASER include coherence, monochromaticity, high directionality, high power, and narrow bandwidth. These properties make MASERs useful for applications such as atomic clocks, communication systems, and astronomical observations.
3. How is a MASER different from a LASER?
A MASER and a LASER (Light Amplification by Stimulated Emission of Radiation) are similar in principle, but operate in different frequency ranges. A MASER operates in the microwave region, while a LASER operates in the optical or infrared region. Additionally, a MASER uses molecules as the amplifying medium, while a LASER typically uses atoms or semiconductors.
4. What are some common applications of MASERs?
MASERs have a variety of applications, including in atomic clocks, satellite communication systems, radar technology, and astronomical observations. They are also used in scientific research and in medical imaging techniques such as magnetic resonance imaging (MRI).
5. What are the current challenges in understanding and utilizing MASER technology?
One of the main challenges in MASER technology is achieving stable and reliable operation at higher frequencies. Another challenge is developing more efficient and compact designs. Additionally, understanding and controlling the properties of the amplifying medium is an ongoing area of research in MASER technology.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
  • Classical Physics
