PainterGuy
- 940
- 70
Hi :)
I'm trying to understand 'background' working of the maximum power transfer which says that power transfer takes place across R_L when it is equal to R_th (R_L is load resistance and R_th is Thevenin resistance). It is easily proved by doing some math.
P=VI, P=I^2.R, P=V^2/R, V=IR
Let's focus on P=V^2/R_L. To have maximum power transfer to R_L, V should be as large as power (V is volts dropped across R_L). V across R_L could be found using voltage divider rule: (R_L x E)/(R_L + R_th). Further R_L should be as little as possible because it is denominator. But also note that making R_L smaller would reduce the volts dropped across R_L.
But now focus on P=I^2.R_L. Compare it with the previous analysis of P=V^2/R_L. In (I^2.R_L), R_L should be as large as possible which is in contrast with the previous analysis which required R_L to be minimum. So some compromise is needed. But there is another point to note. R_L and R_th are in series so if R_L is made too big then the value of I would drop.
I hope you could see where I'm coming from (or, rather trying to come from! :) ). Could you please help me to really understand the working of maximum power transfer theorem? Many thanks.
Cheers
Cheers
