Understanding Momentum in Continuous Mass Flow Problems
In summary, the problem involves a freight car with a mass of mc containing sand with a mass of ms. A constant horizontal force is applied and a port is opened to let the sand flow out at a constant rate. The speed of the freight car when all the sand is gone needs to be found. The momentum at time t is (mc(t))v and at t+ \Deltat it should be (m-\delta m)(v+\delta v)+\delta mv.
unscientific
1,734
From 2.2 Worked Examplehttp://ocw.mit.edu/courses/physics/8-01sc-physics-i-classical-mechanics-fall-2010/continuous-mass-flow/MIT8_01SC_coursenotes19.pdf"
Emptying a Freight Car - A freight car of mass mc
contains a mass of sand ms
At t = 0 a constant horizontal force of magnitude F is applied in the direction of rolling and at the same time a port in the bottom is opened to let the sand flow out at the constant rate b = dms/ dt . Find the speed of the freight car when all the sand is gone. Assume that the freight car is at rest at t = 0 .
It is written that the momentum of vehicle at time t is ( [tex]\Delta[/tex]m + m ) v
Shouldn't the momentum of the vehicle at time t be just (mc(t))v ? by adding [tex]\Delta[/tex]m you're doing it twice!
I don't understand how they got the momentum for time t+ [tex]\Delta[/tex]t too! shouldn't it be (mc - [tex]\Delta[/tex]m)(v + [tex]\Delta[/tex]v)?
I would agree with you that the momentum at time t is (mc(t))v. But disagree with the momentum at t+ [tex]\Delta[/tex]t. It should be
[tex]P(t+\delta t)=(m-\delta m)(v+\delta v)+\delta mv.[/tex]
So the final result should remain as [tex]F=m\frac{dv}{dt}.[/tex]
FAQ: Understanding Momentum in Continuous Mass Flow Problems
What is a continuous mass flow problem?
A continuous mass flow problem is a type of mathematical problem that involves the steady flow of a substance, such as a liquid or gas, through a system. This type of problem is commonly encountered in fields such as fluid mechanics, thermodynamics, and chemical engineering.
How is a continuous mass flow problem solved?
To solve a continuous mass flow problem, you typically need to apply conservation of mass and energy principles, along with any relevant equations or laws that govern the specific system. This often involves setting up a mass balance or energy balance equation and solving for the desired variables.
What are the main challenges in solving a continuous mass flow problem?
One of the main challenges in solving a continuous mass flow problem is accurately defining the system boundaries and understanding all of the relevant factors that influence the flow. Other challenges may include dealing with nonlinear or complex equations, and ensuring that the solution is physically realistic.
What are some common real-world applications of continuous mass flow problems?
Continuous mass flow problems have many applications in industries such as oil and gas, chemical processing, and environmental engineering. They can be used to design and optimize pipelines, pumps, heat exchangers, and other systems that involve the continuous flow of fluids.
What are some strategies for improving the efficiency of continuous mass flow systems?
To improve the efficiency of a continuous mass flow system, you can consider optimizing the flow rate, minimizing pressure losses, or reducing energy consumption. This may involve adjusting the system design, using more efficient components, or implementing control strategies such as feedback control or flow rate modulation.
