Understanding Operators in Matrix Mechanics
In summary, the notes say that if we expand a wavefunction using eigenfunctions, we will get a sum of the original eigenfunctions, with the effect of the operator taken into account. However, I'm having difficulty following how this is represented in equations (2.1).
Avardia
I'm trying to understand some notes that I have been given on Matrix Mechanics, specifically how the matrix element comes about and builds a matrix which when used applies the effect of an operator on a wavefunction. But I'm having some difficulties following what's being done in the notes with confidence. I've seen others do this another way which I can follow well enough but I really want to see how this one works.
As far as I understand the notes start off recapping expansion theorem and say if we work with a single complete set of eigenfunctions to build any old wavefunction then what we get is a unique list of coefficients for each wavefunction we are expanding. We then see an operator acting on a generic wavefunction and since we work with linear operators its equivalent to applying the operator to each of the eigenfunctions that we use to expand the generic wavefunction. Seen in the equation above equation (2.1).
Then comes my problem, just above equation (2.1) we are told
In general the effect of an operator on any eigenfunction will produce a wavefunction which can be represented as a sum of the original eigenfunctions, i.e.
From my understanding the quote says to further expand the result of the operator acting on each of the eigenfunctions we used to expand the generic wavefunction. Also basing that off the use of the subscript i on the LHS of (2.1) and the general flow of where the notes seems to be taking me. Part of my issue is how that is represented in (2.1). What I think (shakily) is happening is that we have applied the operator to the eigenfunction, don't exactly know if the eigenfunction is a eigenfunction of that generic operator, and it will produce a wavefuction which can be expanded using the same eigenfunctions that we used in the first expansion of the generic wavefunction. And here the Oji I believe is the coefficient of the each of the eigenfunctions?
Then putting it all together in the equation below (2.1) is what makes me question what I'm working with here. The operator O is working on a generic wavefunction, that's equal to O working on each eigenfunction that we break the wavefunction into then we get the RHS of (2.1) except we are we are expanding every eigenfunction and we also have the aj coefficient from the original expansion. This is somehow supposed to show me that Oji contains the effect of the operator. I can't seem to see how this works. Will be grateful for any help you can give!
I think ##\bar O## is just an arbitrary operator that looks like this: ##\bar O = \sum_{jm} | \psi_j \rangle O_{jm} \langle \psi_m |##. Try substituting that into each of the equations in your text and see if they make sense.
Related to Understanding Operators in Matrix Mechanics
1. What is a matrix in matrix mechanics?
A matrix in matrix mechanics is a rectangular array of numbers or symbols arranged in rows and columns. It is used to represent physical quantities and their relationships in quantum mechanics.
2. What is an operator in matrix mechanics?
An operator in matrix mechanics is a mathematical object that acts on a matrix to produce another matrix. It is used to represent physical observables and their corresponding transformations in quantum mechanics.
3. How do operators act on matrices in matrix mechanics?
Operators act on matrices in matrix mechanics by multiplying them according to specific rules. The result of this multiplication is a new matrix that represents the transformed physical quantity or observable.
4. What is the significance of operators in matrix mechanics?
Operators play a crucial role in matrix mechanics as they allow us to mathematically describe and manipulate physical quantities and observables in quantum mechanics. They also play a key role in the formulation of the fundamental equations of quantum mechanics, such as the Schrödinger equation.
5. How are operators related to eigenvalues and eigenvectors in matrix mechanics?
In matrix mechanics, the eigenvalues and eigenvectors of an operator represent the possible outcomes and corresponding states of a physical measurement. The eigenvalues represent the possible values of the physical quantity being measured, while the eigenvectors represent the corresponding states of the system. The operator acts on the eigenvectors to produce the corresponding eigenvalues, which can then be measured in experiments.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
