I Understanding Physical Processes: EM, Gravitational, Mechanical & Entropic
The discussion explores the applicability of electromagnetic, gravitational, mechanical, and entropic processes to all physical phenomena. It questions whether electromagnetic interactions are possible within black holes, suggesting that not all physical entities interact electromagnetically. The conversation also examines gravitational forces, noting that while all mass-energy entities exert gravitational influence, distant galaxies may not be affected by the same gravitational fields. Regarding mechanics, it is posited that all physical interactions can be described mechanically, implying a potential equivalence between physicality and mechanical laws. Lastly, the discussion asserts that entropy seems to govern all physical processes, linking it closely with information theory, while also considering the limitations of these interactions in the context of cosmic expansion.
Hallucinogen
Hi, I'm putting together some resources about theories and would like some help to make sure I don't make a mistake.
In particular, I'd like to know if each of the electromagnetic, gravitational, mechanical and entropic processes applies to every physical process.
So, for example, due to an event horizon, I understand that electromagnetic radiation cannot escape the interior of a black hole (hence I'm not referring to Hawking radiation), so therefore is it true not that all physical phenomena/bodies are interacting electromagnetically? The EM forces cannot take the matter inside the black hole and interact it with matter outside it, so there's a set of phenomena that can't be electromagnetic. If so, this would entail that not everything that is physical is electromagnetic, is that right?
I also have the same question about gravitaitonal forces and mechanical forces. Regarding gravitation: is it right that any two things that have energy/mass exert a gravitational force of some size on each other, so is there no entity in physics unaffected by gravitaitonal force? I read that very distant galaxies might not be encompassed by the same gravitaitonal field, is that right?
And for mechanics. I can't think of an example of any physical object or interaction or process that isn't governed by some mechanical description or law. If that's right, does it mean everything that is physical is mechanical, and vice versa? Ie. they are sets with the same elements?
This also seems true of entropy. Any physical process between physical entities appears to be considerable as an entropic process, so it seems to me that entropy covers the whole set of physical processes, is this right? Every known interaction in physics can be expressed in terms of entropic laws, correct?
While this is also true of information theory, information arguably includes more than physical things. There appears to be a close relationship between information theory and entropy, but the subject of entropy appears to specifically be the informational consideration of physical phenomena, ie. it seeks to understand the link between information, matter and energy. Is entropy circumscribed as such?
Many thanks for any help.
Or, for example, two galaxies that have exited each other's light cones and are accelerating away from one another faster than the speed of light due to cosmic expansion no longer have any interaction with one another that can be expressed in terms of EM or gravitation. Is that right?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
