Understanding Poiseuille Equation
  • I
  • Thread starter fog37
In summary, the Poiseuille equation explains the need for a pressure difference in an incompressible and viscous Newtonian fluid in laminar flow, and even in the case of a perfect fluid, a pressure difference is needed to set it into motion. However, the Poiseuille equation does not apply to inviscid flow, where a pressure difference is only needed to start the flow but not to maintain it.
fog37
1,568
108
Hello Forum,
The important Poiseuille equation tells us that there must be a pressure difference in an incompressible AND viscous Newtonian fluid in laminar flow flowing through a cylindrical pipe of constant cross section and radius R and length L. Viscosity hinders fluid motion.
But even in the case of a perfect fluid (zero viscosity) a pressure difference between the two ends of the tube is needed to set the fluid into motion. But the Poiseuille equation seems to tell us that no pressure is needed to maintain an inviscid fluid into motion...I am confused..
thanks,
fog37
The Poiseuille equation has nothing to do with inviscid flow. You can't draw any conclusions about the inviscid case from that equation. And yes, a pressure difference would be required to start an inviscid pipe flow in motion, but not to maintain that motion. If you had a constant pressure difference in that case, then you would have a constantly accelerating flow. With no pressure difference, an inviscid flow just maintains a constant velocity.
When viscousity is included, you need a pressure difference to overcome the resistance of viscosity, thus the Poiseuille equation.
Likes vanhees71
Related to Understanding Poiseuille Equation
What is the Poiseuille equation?
The Poiseuille equation is a mathematical formula that describes the flow of a fluid through a cylindrical pipe or tube. It takes into account factors such as the viscosity of the fluid, the length of the pipe, and the radius of the pipe.
How is the Poiseuille equation derived?
The Poiseuille equation is derived from the Navier-Stokes equations, which are a set of equations that describe the motion of a fluid. It is also based on the Hagen-Poiseuille law, which states that the flow rate of a fluid is directly proportional to the pressure difference and the fourth power of the pipe's radius.
What is the significance of the Poiseuille equation?
The Poiseuille equation is significant because it allows scientists and engineers to calculate the flow rate of a fluid through a pipe or tube. This is important in various fields such as fluid dynamics, biomechanics, and engineering, as it helps in designing and optimizing systems that involve fluid flow.
What are the assumptions made in the Poiseuille equation?
The Poiseuille equation makes several assumptions, including laminar flow (smooth and orderly flow), incompressible fluid, and a constant viscosity. It also assumes that the fluid is flowing through a long, cylindrical pipe with a constant cross-sectional area.
How is the Poiseuille equation used in real-life applications?
The Poiseuille equation is used in various real-life applications, such as designing pipelines for transporting fluids, calculating blood flow in the human body, and determining the flow of air in ventilation systems. It is also used in medical devices, such as catheters and syringes, to ensure a smooth and accurate flow of fluids.
  • Classical Physics
  • Classical Physics
15K
  • Classical Physics
  • Mechanical Engineering
