Is There a Flaw in Understanding Proper Time and Time Dilation?
In summary, a twin paradox occurs when an apparently identical twin who is in a different frame of reference sees their twin as older or younger than they actually are.
Wannabe Physicist
Imagine that space (not spacetime) is actually a finite box, or in more sophisticated
terms, a three-torus, of size ##L##. By this we mean that there is a coordinate system ##x^\mu = (t,x,y,z)## such that every point with coordinates ##(t,x,y,z)## is identified with every point
with coordinates ##(t,x+L,y,z)##, ##(t,x,y+L,z)##, and ##(t,x,y,z+L)##. Note that the time coordinate is the same. Now consider two observers; observer A is at rest in this coordinate system (constant spatial coordinates), while observer B moves in the x-direction with constant
velocity ##v##. A and B begin at the same event, and while A remains still, B moves once
around the universe and comes back to intersect the world line of A without having to
accelerate (since the universe is periodic). What are the relative proper times
experienced in this interval by A and B? Is this consistent with your understanding of
Lorentz invariance?
##(\Delta \tau^2) = (\Delta t)^2-(\Delta x)^2-(\Delta y)^2-(\Delta z)^2##
Let us denote the events in spacetime before the trip has started by subscript 1 and those after the trip is over by subscript 2. So before the trip has begun, the coordinates in spacetime for A and B are
##A = (t_{A_1},x,y,z)## and ##B = (t_{B_1},x,y,z) = (t_{A_1},x,y,z)##.
After the trip is over,
##A = (t_{A_2},x,y,z)## and ##B = (t_{B_2},x+L,y,z)##.
Note that ##\Delta t_A = t_{A_2}-t_{A_1} = \frac{L}{v}## and ##\Delta t_B = t_{B_2}-t_{B_1}##. Now, by the time dilation formula, ##\Delta t_B = (\Delta t_A)/\gamma##
Thus if ##\Delta \tau_A## and ##\Delta \tau_B## are proper time intervals of A and V respectively
$$(\Delta \tau_A)^2 = (\Delta t_A)^2 - 0 - 0 -0 \implies \Delta \tau_A = \Delta t_A$$
$$(\Delta \tau_B)^2 = (\Delta t_B)^2 - L^2 - 0 -0 = \frac{(\Delta t_A)^2}{\gamma^2} - L^2 = \frac{(\Delta \tau_A)^2}{\gamma^2} - L^2 $$
I feel that this must be right. I, with my naive eyes, am not able to see any flaw in my argument. But this blog post: https://petraaxolotl.wordpress.com/chapter-1-special-relativity-and-flat-spacetime/ seems to be telling a different story.
It says $$(\Delta \tau_B)^2 = (\Delta t_B)^2-(\Delta x)^2 = (\Delta \tau_B)^2(1-v^2) = (\Delta \tau_A)^2(1-v^2) = \frac{(\Delta \tau_A)^2}{\gamma^2}$$
Am I making any mistake?
I am skeptical in applying SR which is for observers in IFR to the torus 3D-space+time world which does not seem IFR to me globally.
Likes docnet
I understand your point. But I am trying to teach myself GR and this exercise is in the first chapter of Carroll. He hasn't introduced curvature and stuff yet. Actually, I got the answer. It is ##\Delta \tau_B = \displaystyle\frac{L}{\gamma v}##. The mistake is in writing the coordinates and is very silly. A's and B's coordinates are in reference to A's and B's frames respectively. But in B's frame, the observer is obviously at rest. So we should have ##B = (t_{B_2}, x,y,z)##
Along the problem statement, say starting with zero time adjustment, when they meet again their own proper time are
[tex]\tau_A=\tau_B=\frac{L}{v}[/tex]
and they see others time are by time dilation
[tex]t_A=t_B=\frac{L}{\gamma v}[/tex]
We face contradiction because they have to be
[tex]\tau_A=t_A[/tex]
[tex]\tau_B=t_B[/tex]
One way to avoid the contradiction is to make L infinite or grow with rate of more than c to prohibit them meeting again.
Likes docnet
There is no contradiction, nor even any need to use Lorentz transform. The whole problem can be calculated in in the initial coordinates given. The treatment of SR with nonstandard topology is a well known exercise (it is not considered normal SR though). OP is definitely right as to the answer in post #3.
Due to the periodicity of the spacetime, (L/v,0) and (L/v,L) are the same event (I give time coordinate first). However, the straight (geodesic) path from (0,0) to the first along the (1,0) direction is different from the straight path from (0,0) to the second label along the (1,v) direction. As a result, you simply have two intervals to compare : (L/v,0) and (L/v,L). That's all there is to it, and you get the answer in post #3.
  • Love
Likes docnet
I found contradiction in post #4 which was a kind of twin paradox. I think it is due to my additional assumption that both A frame of reference and B frame of reference are IFRs.
Related to Is There a Flaw in Understanding Proper Time and Time Dilation?
1. What is proper time?
Proper time is the elapsed time measured by a clock that is at rest relative to the system being observed. It is the time experienced by an observer who is moving along with the clock.
2. How is proper time different from coordinate time?
Coordinate time is the time measured by a clock that is at a fixed position in a specific reference frame, while proper time takes into account the effects of time dilation and length contraction due to relative motion.
3. Why is understanding proper time important in physics?
Proper time is a fundamental concept in special and general relativity, and is crucial for accurately describing the behavior of objects in motion. It helps us understand the effects of time and space on the physical world.
4. How is proper time calculated?
Proper time can be calculated using the equation t' = t/√(1-v^2/c^2), where t is the coordinate time and v is the relative velocity between the observer and the clock. This equation takes into account the effects of time dilation.
5. Can proper time be measured?
Yes, proper time can be measured using a clock that is at rest relative to the system being observed. However, it is important to note that proper time can only be measured by an observer moving along with the clock, as it is a relative concept.
  • Differential Equations
