MHB Understanding Quadratic Equations: Solving for x
  • Thread starter Thread starter headbang
To solve the inequality $$\frac{2x-1}{x+3}<1$$, it's essential to consider the sign of the denominator, leading to two cases: when $x + 3 > 0$ and $x + 3 < 0$. The first case simplifies to $$2x - 1 < x + 3$$, yielding the solution $-3 < x < 4$. The second case results in a contradiction, confirming that the only valid solution is within the interval $(-3, 4)$. The critical values at $x = -3$ and $x = 4$ indicate where the sign of the expression changes, and testing values within the intervals confirms the solution.
headbang
Can somone please help me understand this.
maybe a solution with explanation ..
Maby the NeXT step..??
$$ 2x-1<x+3$$
Can we use this in the $$x=\frac{-b\pm\sqrt{b^{2}-4ac}}{2a}$$
Mathematics news on Phys.org
Hi!
You have to take cases for the denominator.
  • $x+3>0 \Rightarrow x>-3$
    Then:
    $$2x-1<x+3 \Rightarrow x<4$$
  • $x+3<0 \Rightarrow x<-3$
    $$2x-1>x+3 \Rightarrow x>4, \text{ that is not possible, since , in this case, } x<-3$$
So, the only solution is $-3<x<4$.
Or maybe:
$$2x-x<3+1$$
$$x<4$$
headbang said:
Or maybe:
$$2x-x<3+1$$
$$x<4$$
This stands only if $x+3>0$.
When we have:
$$\frac{a}{b}<1 $$
and we multiply by $b$, we have to distinguish cases.
If $b>0$:
$$\frac{a}{b} \cdot b<1 \cdot b \Rightarrow a<b$$
If $b<0$:
$$\frac{a}{b}<1 \Rightarrow a>b$$
For example:
$$\frac{5}{-3}<1 \Rightarrow \frac{5}{-3} \cdot (-3)> 1 \cdot (-3) \Rightarrow 5>-3$$
Multiplying both sides of an inequality by a negative number, the direction of the inequality changes ("<" becomes ">").
$$ 2x-1<x+3$$
As mentioned, you don't want to multiply through by a quantity containing the variable, because it may be negative , positive or zero. I would subtract 1 from bot sides to get:
$$\frac{2x-1}{x+3}-1<0$$
Combine terms on the left:
$$\frac{2x-1-(x+3)}{x+3}<0$$
$$\frac{2x-1-x-3}{x+3}<0$$
$$\frac{x-4}{x+3}<0$$
Okay, we now know that the sign of the expression on the left will change at two critical values:
$$x=-3,\,4$$
Because the roots in the numerator and denominator occur an odd number of times (in this case both once), we know the sign of the expression will alternate across the 3 intervals of the real number line into these two critical values divide it. So, I would test a number in the middle interval, specifically $x=0$, and we see that the expression is negative, and satisfies the inequality. Thus, in the left and right intervals, the expression will be positive, and not part of the solution. Since the inequality is strict, the interval is open, thus the solution, in interval notation is:
$$(-3,4)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
