Understanding question : Concentration
In summary: In your first dilution, ##M_1 = 1.70##, ##V_1 = 63.0##, ##V_2 = 248##. You can solve for ##M_2##.In your second dilution, ##M_1## is the new concentration you just calculated from the first dilution, ##V_1 = 124##, ##V_2 = 124 + 167##, and you can solve for ##M_2## again.In summary, we have a 63.0 mL portion of a 1.70 M solution that is diluted to a total volume of 248 mL. From that, a 124 mL portion is taken and
brycenrg
95
63.0ml of a 1.70 M solution is diluted to a total volume of 248mL. A 124-mL portion of that solution is diluted by adding 167mL of water. What is the final concentration? Assume the volumes are additive
What is going on in this equation?
You have 248 mL solution but 63mL of that solution is with the molarity of 1.7.
When it says 124mL portion of that solution is diluted by adding 167mL of water. That would mean of the 248 mL, 167mL is water but it initially says 63mL is a solution. so that would leave extra water. I must be thinking of this wrong. any suggestions?
That's a very strange way to think about it. You have to consider the molarity of the solution after dilution.
I donät get what you are saying. You start with 63 mL of a solution, then dilute that to 248 mL. That gives you 248 mL of solution with a new concentration.
You then take 124 mL of that solution, and dilute it by adding 167 mL of water. That gives you x mL of a solution with a new concentration.
You can basically see the second part of the question as the same as the first part, except the numbers have changed.
Dilutions are just about mass conservation - whatever you put in, is present in the final solution.
brycenrg said:
63.0ml of a 1.70 M solution is diluted to a total volume of 248mL. A 124-mL portion of that solution is diluted by adding 167mL of water. What is the final concentration? Assume the volumes are additive.
You start with a big jug of 1.70 M solution. You draw out 63.0 ml of this solution into a beaker.
You take this beaker with the 63.0 mL of 1.70 M solution and dilute it so that the total volume is now 248 mL.
Take half of this diluted solution, 124 mL, and pour it into a second beaker. Add 167 mL water to this portion of already diluted solution, diluting it even more. What's the final concentration?
Even in chemistry HW, sometimes it helps if you make a sketch of what's going on.
I suppose the ##M_1V_1=M_2V_2## equation would come in handy, here?
Yes, that's just a way of expressing mass conservation in the simplest case.
Related to Understanding question : Concentration
What is concentration?
Concentration refers to the amount of a substance in a given volume or space. It is often represented as the ratio of solute to solvent in a solution.
Why is concentration important?
Concentration is important because it affects the properties and behavior of a solution. It can impact the rate of reactions, the solubility of substances, and the overall effectiveness of a solution.
How is concentration measured?
Concentration can be measured in various ways, including molarity, molality, mass percentage, and parts per million. Each method has its own units and formula for calculation.
What factors affect concentration?
The concentration of a solution can be affected by factors such as temperature, pressure, and the addition or removal of solutes or solvents. The type and amount of solute and solvent can also impact concentration.
What are some examples of concentration in everyday life?
Concentration is a common concept in everyday life. Examples include the strength of a cleaning solution, the percentage of alcohol in a beverage, and the amount of medication in a prescribed dose.
