How to Determine Reaction Products from Given Reactants?
  • Thread starter 312213
  • Tags
    Reaction
In summary: BaO and H2O produce a salt and water. When adding in the net ionic equation, both ions are aqueous so they cancel leaving Ba(OH)2. Is this correct?
52
KHSO4 + KOH→
SO4 + H2O→
P2O5 + H2O→
BaO + H2O→
CrO + SO2→
C6H12O6 + O2 (excess)→
CH4 + O2 (limited)→
NH3 + CO2 + H2O →
NH3 + HCl→
Chemical equations
KHSO4 + KOH→ KOH + KHSO4 Does this stay the same? since the first ion for both molecules are K+?
SO4 + H2O→ HSO3 + O2 This seems correct but just making sure.
P2O5 + H2O→ P(OH)5 + H2O This seems entirely incorrect and I'm not sure how to do this. I think the H2O splits to H+ and OH- but then the O from P2O5 would seem strange to combine with OH-.
BaO + H2O→ Ba(OH)2 What does BaO and H2O produce when reacted?
CrO + SO2→ CrO + SO2 Both seem to have O for the second ion.
C6H12O6 + 9O2 (excess)→ 6CO2 + 6H2O If this is correct, then good. Aside from that, what does excess mean?
CH4 + 3O2 (limited)→ CO2 + 2H2O
NH3 + CO2 + H2O → NH3 + HCO3 I really doubt this is correct but I don't understand how to do three or more reactants.
NH3 + HCl→ NCl + 2H2 This seems strange. Also is does the hydrogen in NH3 have a charge of 1-?
To sum it up, I'm not clear on how to determine the products from a given reaction, or understand the kind of reaction it is (synthesis, decomposition, displacements...). What is the way to understand which does what? Unless I am over thinking it.
Another part is what products are formed if the first ions or second ions of compounds, for double displacement/replacement, are same?
Edit: The purpose of these equations were for balancing the net ionic equations. Do I have to do acid-base reactions for it too?
acd/base
Are you sure it was SO4 on the left? Not SO3 or SO2 or SO42-?
To some extent these questions are similar. This is about metal oxides and nonmetal oxides reacting with water. There are some simplified rules that help predict products.
Again, simple rule that states what happens when metal oxide reacts with nonmetal oxide.
Have you checked if it is balanced?
Excess means in this case that there is enough oxygen to fully oxidize carbon.
And there is not enough oxygen here, so one of the products must be different.
Other two ignored, enough hints for one post.
So why there are no ions in your approach?
KHSO4 + KOH → K2SO4 + H2O
2K+ + HSO4- + OH- → 2K+ + SO42- + H2O
HSO4- + OH- → SO42- + H2O
When acid and base react, salt and water is formed. When putting in net ionic equation, the first three molecules are aqueous, so they split into ions, and the H2O is liquid, so it stays together. The 2K+ are canceled from both sides leaving HSO4- + OH- → SO42- + H2O. Is this done correctly for net ionic equation?
For balancing net ionic equations, do I split up the soluble molecules into ions if they aren't double replacement/displacement?
SO4 + H2O →
Yes, I am sure that it is SO4. I wasn't sure about this either so I asked to make sure. What I was thinking was that SO4 cannot exist as a molecule and instead is supposed to be SO42-. Assumed that the SO4 is instead SO3, would the reaction be:
SO3 + H2O → H2SO4
SO3 + H2O → 2H+ + SO42-
Would this be the correct net ionic equation, since the first two are liquid and since H2SO4 is a strong acid, it splits up into ions? Nonmetal oxide with water produces an acid.
P2O5 + H2O → H3PO4
P2O5 + H2O → 3H+ + PO43-
For the most part, same as above reasoning.
BaO + H2O → Ba(OH)2
Ba2+ + O2- + H2O → Ba2+ + 2OH-
O2- + H2O → 2OH-
Metal oxide with water produces a base. BaO and Ba(OH)2 are aqueous so they split up and the Ba2+ cancel leaving O2- + H2O → 2OH-. Is this correct?
CrO + SO2 → CrSO3
Metal oxide with nonmetal oxide produces an oxysalt.
C6H12O6 + 6O2 (excess)→ 6CO2 + 6H2O
I forgot the oxygen from the C6H12O6.
CH4 + O2 (limited)→ 1/3CO2 + 2/3H2O
I am still not sure how to write limited in the equation. Would the limited mean I have only one mole of oxygen? Which is a third of the required oxygen? Which reduces the products by a third? And does the limited make CH4 have a 1/3 coefficient because only a third of a mole of CH4 is required with one mole of oxygen?
Yes.
Kidn of reaction doesn't matter, if it is net ionic, you split it into ions.
That's why it doesn't make sense.
SO3 + H2O → H2SO4
First one is correct, as for the second one - H2SO4 is a strong acid, HSO4- is much weaker, so - especially in more concentrated solution - sulfuric acid is not fully dissociated. That's why it is hard to say if your reaction is correct or not.
P2O5 + H2O → H3PO4
First OK (balancing won't hurt). Second - phosphoric acid is generally much weaker than othe rmineral acids.
[BaO + H2O → Ba(OH)2
OK
O2- + H2O → 2OH-
No such thing as aqueous BaO, it immediately reacts with water - see the reaction above.
Please reread what I wrote earlier.
FAQ: How to Determine Reaction Products from Given Reactants?
1. What are reaction products?
Reaction products are the substances that are formed as a result of a chemical reaction. They are the end products of the reaction and can be different from the starting materials.
2. How do you determine the reaction products?
The reaction products can be determined by balancing the chemical equation and understanding the reactants and their properties. The products can also be identified through experiments and analysis techniques such as spectroscopy or chromatography.
3. What factors influence the formation of reaction products?
The formation of reaction products is influenced by factors such as the nature of the reactants, temperature, pressure, concentration, and the presence of catalysts. These factors can affect the reaction rate and the direction of the reaction, leading to different products.
4. How do you predict the type of reaction products?
The type of reaction products can be predicted by understanding the type of chemical reaction taking place, such as synthesis, decomposition, single or double replacement, or combustion. Additionally, the properties of the reactants can give clues about the possible products.
5. Why is it important to understand reaction products?
Understanding reaction products is crucial for many reasons. It allows us to predict the outcome of a chemical reaction and design new reactions to produce desired products. It also helps in explaining natural phenomena, developing new products, and understanding the properties and behavior of substances. Additionally, understanding reaction products is essential in fields such as medicine, environmental science, and materials science.
