Understanding resonance in a spring
In summary, the conversation discusses the equation $\frac{d^2y}{dt^2} + 5y = 0$ and its solution $y = Acos(\sqrt5t) + Bsin(\sqrt 5 t)$. It also introduces an external force $Acos(\omega(t - \phi))$ and discusses the resulting equation $\frac{d^2y}{dt^2} + 5y = -4Bsin(\sqrt 5 t) = Acos(\omega(t - \phi))$. However, there are some errors in the assumptions made and the final conclusions presented. The correct values for resonance are $\omega = -\sqrt 5$ and $\phi = \frac{\
Pochen Liu
52
I have an equation which I used a double derivative to solve, now I need to find values for the variables such that when external force is applied resonance occurs
*Attached
I have the equation $$\frac{d^2y}{dt^2} + 5y = 0$$
where I've worked out $$y = Acos(\sqrt5t) + Bsin(\sqrt 5 t)$$
$$y'' = -5Bsin(\sqrt 5 t)
using $$y = e^{\lambda x}$$ and using y(0) = 0 (the spring is released from equilibrium)
so an external force $$Acos(\omega(t - \phi))$$ is applied so we therefore
$$\frac{d^2y}{dt^2} + 5y = -4Bsin(\sqrt 5 t) = Acos(\omega(t - \phi))$$
$$-4Bsin(\sqrt 5 t) = -4Bcos(\frac{\pi}{2} - \sqrt 5 t)$$
so $$\frac{\pi}{2} - \sqrt 5 t = \omega(t - \phi)$$
$$-\sqrt 5(t-\frac{\pi}{2 \sqrt 5}) = \omega(t - \phi)$$
we can conclude that these are the values to create resonance
$$ \omega = - \sqrt 5 $$
$$ \phi = \frac{\pi}{2\sqrt5}$$
A = any positive integer as only they only need to be in phase, so any amplitude is added
Are these the right conclusions?
The left hand side equals the right hand side, but the term in the middle makes no sense.
You seem to be assuming that the solution to the unforced case still applies, but it doesn't, and you have also made an arithmetic error. The arithmetic error gave you a 4 instead of 0.
Likes Pochen Liu
FAQ: Understanding resonance in a spring
What is resonance in a spring?
Resonance in a spring is a phenomenon that occurs when the frequency of an external force matches the natural frequency of the spring. This causes the spring to vibrate with maximum amplitude.
How does resonance in a spring happen?
Resonance in a spring occurs due to the transfer of energy between the external force and the spring. When the frequency of the external force matches the natural frequency of the spring, the energy transfer is most efficient and causes the spring to vibrate with maximum amplitude.
What factors affect the resonance frequency of a spring?
The resonance frequency of a spring is affected by its stiffness, mass, and length. A stiffer spring will have a higher resonance frequency, while a longer or heavier spring will have a lower resonance frequency.
How does resonance in a spring affect its behavior?
When a spring is in resonance, it will vibrate with maximum amplitude, which can cause it to oscillate for a longer period of time. This can also lead to increased stress on the spring and potential damage if the resonance frequency is not controlled.
How is resonance in a spring used in practical applications?
Resonance in a spring is used in various practical applications, such as in musical instruments and shock absorbers. In musical instruments, the resonance frequency of the spring determines the pitch of the sound produced. In shock absorbers, resonance is used to absorb and dissipate energy, reducing the impact of vibrations on a vehicle or structure.
