Understanding sound transmission loss (TL)
In summary: TL = 10*Log(W1/W2)In summary, TL is the ratio of sound powers, and Lt is the extent to which power of the reflected wave is diminished relative to that of the incident wave due to some of the power transmitted through the wall.
Pete_L
27
In considering a sound wave (in air) incident on a wall, the transmission loss (TL) is calculated by the equation
TL (dB) = 10*Log (W1/W2)
where
W1 = sound power incident on wall
W2 = sound power transmitted through wall
Based on this understanding of TL, I wish to determine the extent to which TL diminishes sound power of the reflected sound wave. Understanding that W1/W2 is the ratio of sound powers, I calculated
Lt (dB) = 10*Log [ 1- (W2/W1)]
where
Lt = the extent to which power of the reflected wave is diminished relative to that of the incident wave due to some of the power transmitted through the wall
This might become part of an article that I hope will be published. As I am not a professional, I just wanted to check that my derivation from the standard equation for transmission loss is correct. So thanks if someone who is knowledgeable concerning acoustics can confirm that this is correct or not.
-Pete
To make this easier to respond to, here is how I derived the equation for Lt.
Consider the fraction below,
[(W1/W2) -1] / (W1/W2)
If for example W1/W2 equals 10, this means 10 parts incident sound power to 1 part transmitted power. In the numerator, 10 minus 1 equals 9. The denominator is the original ratio of 10 without subtracting the 1 part of transmitted sound power. Thus,
10*log [((W1/W2) - 1 ) / (W1/W2)] = 10*log 0.9 = -0.46 dB
This tells me that power in the reflected wave with respect to power of the incident wave has been diminished by about 0.5 dB as a result of some of the energy transmitted through the wall.
Simplifying the fraction,
(W1/W2) -1 = (W1 - W2) / W2
[(W1- W2) / W2] * 1/(W1/W2) = (W1- W2)/ W1
(W1 - W2)/ W1 = 1 - (W2 / W1)
Then
Lt = 10*Log [1- (W2 / W1)]
Please tell me if this is a false line of reasoning, or not. Thank you in advance if anyone can.
-P
I think the simple model for reflection you are using assumes that the wall is acting like a piece of mismatched transmission line.
But W2 will be affected by the heat losses in the wall. You would need to define W2 as the sound power entering the wall rather than the sound power radiated on the far side.
An analogue might be the power reflected from a mismatched attenuator in a transmission line.
Likes sophiecentaur and davenn
My approach is to separately calculate loss due to absorption and transmission. I came across an equation for approximating transmission loss only. Then I also can approximate absorption knowing what the material of the wall is and knowing the absorption coefficient for that material.
But my question is- Is my method of deriving an equation for attenuated power of the reflected sound wave correct? Assume that I have a correct value of W2, whatever that is.
-P
-P
Yes, correct I believe.
Isnt all this just restating conservation of energy? Eg...
Incident power - transmitted power - absorbed power - reflected power = 0
Thank you, I'm not always as rigorous as I should be in solving a problem.
-P
What I need to solve is dB of loss, or reflected power relative to incident power in dB, without regard to the amount of acoustic power involved. So regardless of any particular incident power, the reflected power is reduced by some dB amount.
Yes, but I think the OP question related to the use of decibels, which can be tricky when subtraction or addition are involved.
Likes CWatters
where
Your first equation assumes zero reflection. As you assume zero reflection, it seems odd to use this formula to find something about reflected wave.
The complete formula should be
## L_t=10 log \frac{W1(1-R)}{W2} ##
where R is the coefficient of reflection (intensity) at the interface.
The intensity of the reflected wave depends on the impedance mismatch at the interface. You want to study deviations from Frenel's equations predictions due to absorption in the second medium?
Likes tech99
Related to Understanding sound transmission loss (TL)
1. What is sound transmission loss (TL)?
Sound transmission loss (TL) is a measure of how much sound energy is blocked or absorbed as it travels through a material. It is typically measured in decibels (dB) and can vary depending on the frequency of the sound.
2. How is sound transmission loss (TL) measured?
Sound transmission loss is measured by comparing the sound energy on one side of a material to the sound energy on the other side. This is done using specialized equipment and following specific testing procedures set by organizations such as ASTM International or ISO.
3. What factors affect sound transmission loss (TL)?
The main factors that affect sound transmission loss are the material's density, thickness, and stiffness. Additionally, the frequency and angle of the sound waves, as well as any air gaps or openings in the material, can also impact TL.
4. What is a good sound transmission loss (TL) rating for building materials?
A good TL rating for building materials depends on the intended use and location of the building. Generally, higher TL ratings are desired for soundproofing or noise control purposes. For example, a TL rating of 50 dB or higher is considered good for blocking mid to high-frequency sounds, while a TL rating of 70 dB or higher may be necessary for blocking low-frequency sounds such as traffic noise.
5. How can sound transmission loss (TL) be improved?
Sound transmission loss can be improved by using materials with higher density, thickness, and stiffness, as well as by minimizing any air gaps or openings in the material. Adding multiple layers of material or using sound-absorbing materials can also help improve TL.
  • Classical Physics
  • Electrical Engineering
