Understanding the Area of a Curve: A^4 Y^2 = X^4 (A^2 - X^2)
  • MHB
  • Thread starter Suvadip
  • Tags
    Area Curve
In summary, the conversation discusses finding the area of the loop of the curve a^4 y^2=x^4(a^2-x^2). The speaker suggests exploiting the symmetries of the curve and considering only the first quadrant to simplify the problem. They also mention using a trigonometric substitution after finding the x-intercepts as limits of integration. The conversation ends with the speaker giving the listener a chance to continue from where they left off.
Suvadip
74
I have to find the area of the loop of the curve \(\displaystyle a^4 y^2=x^4(a^2-x^2).\)
I have confusion regarding the shape of the graph the limits of integration.
I would first exploit the symmetries of the curve and consider only the first quadrant. Then find the $x$-intercepts to obtain the limits of integration, after which a trigonometric substitution works nicely.
Can you proceed?
As we can see, there are only even powers of $x$ and $y$, and so we know there is symmetry across both coordinate axes. And so the total area $A$ enclosed will be 4 times the area in the first quadrant. The non-negative $x$-intercepts are found by equating $y$ to zero:
\(\displaystyle 0=x^4\left(a^2-x^2 \right)=x^4(a+x)(a-x)\)
And so we find these intercepts are at:
\(\displaystyle x=0,\,a\)
And so we may state:
\(\displaystyle A(a)=\frac{4}{a^2}\int_0^a x^2\sqrt{a^2-x^2}\,dx\)
At this point, we may consider the substitution:
\(\displaystyle x=a\sin(\theta)\,\therefore\,dx=a\cos(\theta)\)
So, I will now stop at this point to give you a chance to take it from here. :D
FAQ: Understanding the Area of a Curve: A^4 Y^2 = X^4 (A^2 - X^2)
What is the formula for calculating the area of a curve represented by the equation A^4 Y^2 = X^4 (A^2 - X^2)?
The formula for calculating the area of a curve represented by the equation A^4 Y^2 = X^4 (A^2 - X^2) is A^2*X^2/2.
How is the equation A^4 Y^2 = X^4 (A^2 - X^2) derived?
The equation A^4 Y^2 = X^4 (A^2 - X^2) is derived from the general formula for calculating the area under a curve, which is the integral of the curve's equation with respect to the x-axis.
Can the equation A^4 Y^2 = X^4 (A^2 - X^2) be used to find the area of any curve?
Yes, the equation A^4 Y^2 = X^4 (A^2 - X^2) can be used to find the area of any curve, as long as the curve can be represented by this equation.
How does the value of A affect the area of the curve?
The value of A in the equation A^4 Y^2 = X^4 (A^2 - X^2) affects the area of the curve by determining the overall shape and size of the curve. As A increases, the curve becomes wider and the area under the curve increases. As A decreases, the curve becomes narrower and the area under the curve decreases.
Is there a way to graphically visualize the area under the curve represented by the equation A^4 Y^2 = X^4 (A^2 - X^2)?
Yes, the area under the curve represented by the equation A^4 Y^2 = X^4 (A^2 - X^2) can be graphically visualized by plotting the curve on a graph and then shading in the area between the curve and the x-axis. This shaded area represents the calculated area under the curve.
