Understanding the Behaviour of 1/a: Even or Odd?
  • Thread starter phymatter
  • Tags
    even
In summary, the conversation discussed the concept of even and odd numbers in relation to their reciprocals and how they can only be defined for integers. It was also mentioned that there is no uniform distribution on the integers and that the probabilities tend to 1/2 as the limit, but not necessarily starting at 1/2. The conversation also touched on the idea of sampling even and odd numbers and how the probability of picking a random positive integer starting with the digit 1 is not well-defined. Ultimately, the practical application of these concepts may vary and cannot be determined without specifying the situation.
phymatter
131
even or odd?
if a is an even number , what can we say about 1/a ;
similarly if a is an odd number , what can we say about 1/a?
Mathematics news on Phys.org
Numbers can only be even or odd if they're integers. Is 1/a going to be an integer?
Pretty much nothing in either case. When we talk about even or odd numbers, we're really talking about even or odd integers; that is, whether the remainder is 0 or 1 when we divide by 2. The reciprocals of integers aren't generally integers.
You can say...that if a is a random odd number, that it is more likely that a is larger than if a is a random even number.
1 3 5 7 9 = 25
2 4 6 8 10 = 30
I think I got that right *blinks*.
No.
First, there's no such thing as a uniform random distribution on the integers. Second, if you take the limit of the uniform distribution on [0, N] as N increases without bound, you get probability 1/2 for both.
if we cannot decide weather a fractional number is even or odd then how can we tell that weather a negative number raised to a fractional power is positive or negative?
given answer is to be a real number...
If a negative number, raised to a fractional power, is real, then that power is defined to be positive. That is, we define [itex]a^{1/2}[/itex] to be the positive number, x, such that [itex]x^2= a[/itex].
If x is a negative number, x1/n is:
Not a real number if n is even. Any real number raised to an even power gives a positive number (or 0), so x1/n doesn't exist.
Negative if n is an odd number. A positive number raised to an odd power gives another positive number, so x1/n is always negative.
But this has nothing to do with deciding whether 1/n is even or odd, it's just properties of real numbers
CRGreathouse said:
No.
It *tends* to 1/2. It isn't 1/2 to begin with. ._.
Can't you say that if a is even 1/a will terminate, and if a is odd 1/a will be infinite repeating? omitting when a = 1.
No, that's not true. 6 is even, but 1/6 has an infinitely repeating decimal representation - .1666666...
The probabilities *tend* to 1/2, but the limit of them *is equal to* 1/2. Of course this limit need not be the probablity of anything.
If using every even and every odd number, then yes. But with a real application, the numbers are usually obviously finite. >.>
That's incorrect.
You'll have to say how you sample them. Depending on that answer you might find odds larger on average, evens larger on average, or neither larger on average.
as a range with an equal number of even and odd integers
That's pretty arbitrary, why not one more odd than even? Is the practical situation as apparent when it comes to testing different things? If you pick a random positive integer, what is the probability for that it starts with the digit 1? Given that you can pick at random this probability must exist. To what would a "practical situation" determine this value?
You may work it out if you want, but you'll realize that if you start out with the numbers [1,N] and calculating the probability for this collection, your probability will not converge as N grows towards infinity. Hence two "practical situations" can give two completely different answers, and you can never choose N so large that the difference will be negligible.
FAQ: Understanding the Behaviour of 1/a: Even or Odd?
What is the concept of 1/a being even or odd?
The concept of 1/a being even or odd refers to the behavior of fractions with a denominator of 1. If the numerator is an even number, then 1/a will be an even number. If the numerator is an odd number, then 1/a will be an odd number.
How can you determine if 1/a is even or odd?
To determine if 1/a is even or odd, you can look at the numerator of the fraction. If the numerator is an even number, then 1/a will be an even number. If the numerator is an odd number, then 1/a will be an odd number.
What is the significance of understanding the behaviour of 1/a being even or odd?
Understanding the behaviour of 1/a being even or odd can help in simplifying fractions and solving equations involving fractions. It also provides a better understanding of the relationship between numerators and denominators in fractions.
Can 1/a be both even and odd?
No, 1/a cannot be both even and odd. It can only be one or the other, depending on the value of the numerator. For example, if the numerator is 4, then 1/a will be an even number. If the numerator is 5, then 1/a will be an odd number.
How does the behaviour of 1/a being even or odd affect mathematical operations?
The behaviour of 1/a being even or odd affects mathematical operations involving fractions, such as addition, subtraction, multiplication, and division. For example, adding two even fractions will result in an even fraction, while adding an even fraction and an odd fraction will result in an odd fraction.
