Understanding the Carnot cycle
In summary, the Carnot cycle involves adding heat to the boiler, expanding the steam to do work, cooling the gas, and then compressing it back to the boiler in order to complete the cycle. The point of compressing the gas is to ensure that the cycle can be repeated continuously and to determine the efficiency of the machine. The temperature of the gas needs to be lowered in order to restart the cycle and match up with the phases of the Carnot cycle. The machine design may vary, but this is one common approach.
Mr Davis 97
1,462
44
My textbook explains the Carnot cycle as follows:
1. Heat is added to the boiler, where the steam inside expands isothermally at high temperature (T(High))w(both valves closed).
2. The intake valve is opened (exhaust valve closed) and the steam expands adiabatically. The expanding steam does work by pushing the piston out.
3. As a result of the expansion, the gas cools to the lower temperature (T(Low)).
4. The exhaust valve opens (intake valve closed). The piston compresses the cool gas and pushes it out to the exhaust (isothermal compression). The condenser removes heat from the steam to the air outside, and steam condenses to lower-temperature liquid.
5. A pump moves water to the boiler (adiabatic compression).
I understand step 1, 2, and 3; however, step 4 and 5 I don't grasp. I know that The first steps entail expanding a gas while keeping it at the same temperature, opening the intake valve in order to use the expanding gas to move a piston and do work, and I understand that, according to the first law of thermodynamics, the internal energy of the gas decreases as a result of this work. However, what is the point of step 4 and 5? Why does the gas need to be compressed? Why can't it just go back to the boiler as is? In addition to answering, could someone, in plain language, explain what steps 4 and 5 are for? For example, I am confused about the point that step 4 says that the gas is already cool because it lost energy from doing work. If so, then why is there a lower-temperature reservoir at all. Also, what does "compress" mean in the contexts of step 4 and 5? What is the purpose of this "compression?"
Science news on Phys.org
The cycle needs to end up where it started so that a second identical cycle can begin. Unless the process ends up where it started (completes the cycle), there is no way to know what the efficiency of a continuously running machine is.
Why does the temperature of the gas need to be lowered in order to restart the cycle?
It is describing a typical steam piston machine and indicating how the phases of the Carnot cycle match up. The machine doesn't have to be designed this way, but this is one machine design. The matching parts of the Carnot cycle are not perfect or clear cut. Clearly, the piston must return to the top and push the gas out the exhaust. Because the volume is decreasing during this, and the gas is being pushed out, all at the lower temperature, this matches the isothermal compression stage of the Carnot cycle. The steam could just be exhausted to the atmosphere rather than being condensed and returned to the tank.
Related to Understanding the Carnot cycle
1. What is the Carnot cycle and why is it important in thermodynamics?
The Carnot cycle is a theoretical thermodynamic cycle that describes the most efficient way in which a heat engine can operate. It is important because it sets the maximum limit for the efficiency of any heat engine, and it provides a benchmark for comparing the performance of actual engines against this theoretical ideal.
2. How does the Carnot cycle work?
The Carnot cycle consists of four reversible processes: isothermal compression, adiabatic expansion, isothermal expansion, and adiabatic compression. In each process, heat is either added or removed from the working fluid, and the fluid undergoes a series of changes in temperature and pressure. This cycle allows for the conversion of heat into work with maximum efficiency.
3. What are the key components of a Carnot cycle?
The key components of a Carnot cycle include a heat source (usually a high-temperature reservoir), a working fluid (such as a gas or liquid), a heat sink (usually a low-temperature reservoir), and a piston or other device to do work. These components work together to transfer heat and perform mechanical work in a cyclical manner.
4. What are the limitations of the Carnot cycle?
The Carnot cycle is a theoretical model that assumes ideal conditions, such as perfect insulation and reversible processes. In reality, these conditions are difficult to achieve, and therefore the efficiency of actual engines will always be lower than the theoretical maximum. Additionally, the Carnot cycle does not consider practical limitations, such as friction and heat losses, which further decrease efficiency.
5. How is the efficiency of a Carnot cycle calculated?
The efficiency of a Carnot cycle is calculated using the Carnot efficiency formula: efficiency = (1 - Tcold/Thot) * 100%, where Thot is the temperature of the heat source and Tcold is the temperature of the heat sink. This formula shows that the efficiency of the cycle is dependent on the temperature difference between the two reservoirs, with a higher temperature difference resulting in a higher efficiency.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
