Understanding the curvature parameter k
In summary, the curvature parameter k is a constant in the Robertson-Walker metric and the Friedmann equations, determined by observation and not changing over time. A strictly flat universe will always remain flat while closed or open universes may change their degree of curvature. Curvature is a characteristic of the 4-dimensional spacetime manifold as a whole, not of any individual component, and cannot be described in terms of 1-dimensional subsets. The FLRW coordinates used to describe the universe may result in flat 3-dimensional slices being cut out of a curved 4-dimensional spacetime, and the choice of coordinates can affect the apparent curvature of these slices.
throneoo
126
According to my understanding, k is a constant in the Robertson-Walker metric and the Friedmann equations. Its value (-1,0 or 1) is determined by observation (e.g. the bending of light) and doesn't change over time, unlike the curvature density parameter ##\Omega_k##. Therefore a strictly flat universe will always stay flat, while closed or open universes can change their degree of curvature over time. Is my understanding correct?
2.)
If k=0, then the universe is spatially flat. However spacetime is curved by energy/mass via the stress-energy tensor in a non-empty universe. Since spacetime has to be curved somehow, does that mean time is the only component of spacetime that is curved? Otherwise, how can a massive universe stay flat without some sort of "negative energy" to cancel out the curvature?
I have very limited understanding in general relativity
Space news on Phys.org
The FLRW curvature parameter is a parameter of the spacetime as a whole. So it would not mean anything to say it changes over time. It would be like saying the length of a rod changed between different parts of the rod.
The spatial curvature of the constant-time hypersurfaces of an elliptic or hyperbolic spacetime changes over time in the FLRW model, as space expands. But that spatial curvature measure is a different measure from the k parameter.
Similarly with this one. Spacetime curvature is a property of the four-dimensional spacetime manifold, not a property of any component of it. We can talk about the curvature of 3D spatial slices of the manifold ('constant-time hypersurfaces'). But we cannot talk about the curvature of any one-dimensional subset, since at least two dimensions are needed for curvature to be possible.
andrewkirk said:
The curvature parameter is a parameter of the spacetime as a whole. So it would not mean anything to say it changes over time. It would be like saying the length of a rod changed between different parts of the rod.
Okay. So k is a parameter of spacetime, but it only characterize the curvature of 3D space?
andrewkirk said:
Similarly with this one. Curvature is a property of the four-dimensional spacetime manifold, not a property of any component of it. We can talk about the curvature of 3D spatial slices of the manifold ('constant-time hypersurfaces'). But we cannot talk about the curvature of any one-dimensional subset, since at least two dimensions are needed for curvature to be possible.
I see. Since it doesn't make sense to talk about 1D time-curvature and given that the 3D space is flat, k=0 would correspond to a Minkowski space. How is it possible if matter/energy content is non-zero? A similar question I have is, knowing that according to the Friedmann equation an empty universe with no radiation or mass has negative curvature. But isn't an empty universe supposed to be flat?
But it does make sense to talk about spacetime curvature of a 4-D spacetime in which 3-D spatial slices happen to be flat, which is what andrewkirk was talking about. See below.
No, it wouldn't. Minkowski spacetime is a flat 4-D manifold, not a flat 3-D manifold. In a FLRW spacetime with k = 0, individual spatial slices of constant FLRW coordinate time are flat; but the spacetime as a whole is curved. The k = 0 FLRW spacetime just happens to be curved in such a way that you can cut flat 3-D slices out of it (as long as you cut them in a particular way).
Negative spatial curvature. Once again, spatial curvature, the curvature of 3-D slices cut out of the 4-D spacetime, is not the same as the curvature of the 4-D spacetime.
The empty universe is flat as a 4-D manifold; it is flat Minkowski spacetime. But the FLRW coordinates, in this case, cut 3-D slices out of that flat spacetime that are curved, because of the way they are cut. Just as you can (in certain cases) cut flat 3-D slices out of a curved 4-D spacetime, you can also cut curved 3-D slices out of a flat 4-D spacetime.
From what I can gather, the curvature on space also depends on how the choice of coordinate system (or how they are cut).
Would it be correct to draw such the following analogy from 3D Euclidean space?
3D Euclidean space can either be described by cartesian coordinates or spherical-polar coordinates. If I fix one of the coordinates in the former I'll always get flat slices of 2D surfaces(planes), whereas if I fix the ##r## or ##\theta## coordinates in the latter I will get curved 2D surfaces like spheres and cones, but in either case the 3D space is still Euclidean, just as an empty universe is still a flat (Minkowski) 4D manifold despite having negative spatial curvature in the FLRW coordinates.
Yes, the choice of coordinates determines how the spatial slices are cut out of spacetime.
Yes, in general this is a good way of understanding how choosing coordinates can change the curvature of slices.
However, I do have one correction: cones are not curved surfaces. That is, they have zero intrinsic curvature, which is the kind of curvature we are talking about here. The fact that the cone looks curved when embedded in Euclidean 3-space just means it has extrinsic curvature, which is not the same thing. One way of seeing that a cone has zero intrinsic curvature is to imagine taking a triangle drawn on a flat piece of paper and then rolling the paper up into a cone; you should be able to convince yourself that you can do so without distorting the triangle in any way, i.e., without changing the lengths of any of its sides or any of its interior angles. Whereas, if you try to wrap the flat piece of paper around a sphere, you can't do it without distorting the triangle, either by changing side lengths or angles (or both), illustrating that the sphere has nonzero intrinsic curvature.
throneoo said:
1.)
Note that the convention of k being (-1, 0, 1) is a convention: this is allowed only if we can modify the scale factor. With this convention, the scale factor becomes the radius of curvature.
Another convention that is often used sets the scale factor ##a = 1## at the current time. With this convention, k is just a real number, and is equal to the inverse of the current radius of curvature squared, and a sign set by whether the universe is open or closed (with flat still being k=0).
throneoo said:
2.)
In a spatially-flat universe, the space-time curvature is the expansion. If the universe isn't flat, the expansion still makes up a big part of the space-time curvature, but the spatial curvature also contributes.
FAQ: Understanding the curvature parameter k
What is the curvature parameter k?
The curvature parameter k is a value that describes the curvature of a space. It is commonly used in the field of cosmology to describe the shape of the universe.
How is the curvature parameter k measured?
The curvature parameter k is measured by analyzing the geometry of space using mathematical models and observations from telescopes and other instruments. It can also be calculated using data from experiments and observations of the cosmic microwave background radiation.
What are the different values of the curvature parameter k?
There are three possible values for the curvature parameter k: positive, negative, and zero. A positive k indicates a closed universe, a negative k indicates an open universe, and a zero k indicates a flat universe.
How does the curvature parameter k affect the evolution of the universe?
The value of the curvature parameter k has a significant impact on the evolution of the universe. It determines the overall shape of the universe, the rate of expansion, and the ultimate fate of the universe. For example, a positive k would result in a universe that eventually collapses in on itself, while a negative k would result in a universe that expands forever.
Can the curvature parameter k change over time?
The curvature parameter k is a constant value that does not change over time. However, the curvature of space can change over time due to the effects of matter and energy within the universe. This can lead to a change in the overall value of k, but it remains constant at any given point in time.
