Understanding the Electric Displacement Field
In summary, the displacement field, D, is equal to the total field within a dielectric, which is smaller in magnitude than the applied field due to the opposing field produced by charge separation and the polarization. The polarization is in the opposite direction of the field generated by the dipole material, which opposes the applied field. The equation D = εE, where E is the total field, may seem counterintuitive because multiplying by ε would increase the magnitude of the right-hand side. However, this is due to the convention of writing the bound electric field as -P, even though it is not necessarily in the opposite direction of the total and free fields. The polarization is best defined as the average dipole moment of molecules in a small
sigma_
34
I'm in an upper division undergrad E&M course using Griffths' Electrodynamics text, and I've been struggling to understand the intuition/motivation behind the displacement field, D.
1) D is defined as 0E + P), and is sometimes referred to as the flux density vector.
In LIH dielectrics, P is proportional to E by the relationship
2) P = ε0χeE
Making the substitution with the original definition:
3) D = (ε0E + ε0χeE) → D = εE (using the definition 1+χer)
To me, what these equations are saying is (please forgive my less than formal language, I'm making my best attempt)
1) The displacement field at some point within a dielectric (or anywhere, for that matter) is equal to the field within it, which is smaller in magnitude than the applied field, because it is weakened by the opposing field produced by the separation of charge at the outside edges of the dipole material (the "head" of one dipole canceling the oppositely charged "tail" of the neighboring dipole in the media) plus the Polarization (dipole moment per unit volume), which is in the opposite direction of the field generated by the dipole material which opposes the applied field (field due to free charge). By adding these two quantities, we essentially ignore the field of the dipole and retrieve something equal in magnitude to the field due to only the free charge.
This, to me makes sense, since the closed surface integral of D (dot) dA is equal to the free charge enclosed:
But what are 2) and 3) really saying?
If in 3) we say D = εE where E is the total field in the dielectric, multiplying by epsilon must serve to increase the magnitude of the RHS of the equation because D is also defined by the field of only the free charge, which must be greater than the field of the free charge minus the opposing field due to polarization.
but then how can 2) make sense? How can the polarization be larger in magnitude than the field in the dielectric?
I feel as though my understanding of something here must be completely backwards.
hi sigma_! :smile:
E D and -P are the electric fields due to the total charge, the free charge, and the bound charge, respectively
since the bound electric field is (usually) in exactly the opposite direction to the free and total fields D and E (since it is caused by the molecular dipoles opposing D), it is conventionally written as minus P, so that all three letters represent fields in (usually) the same direction
i think it's that minus which is confusing you :wink:
Yes, this is almost right (in SI the electric field enters the definition of ##\mathbf D## in the expression ##\epsilon_0 \mathbf E##).
(bold mine)
While this may be correct inside dielectric in some cases (dielectric inside a thin capacitor), generally it is not true. It is true when the polarization is proportional to minus the electric field due to bound charges. This need not be so, because the polarization (by definition) satisfies different boundary condition from the electric field of bound charges; the condition is ##\mathbf P = 0## in vacuum, while the electric field due to the dielectric satisfies only ##\lim_{|\mathbf r| \rightarrow \infty}\mathbf E_d(\mathbf r) \rightarrow 0##, and can be non-zero in vacuum.
For thin capacitor the electric field due to the dielectric ##\mathbf E_d## satisfies the same boundary condition as polarization, namely ##\mathbf E_d = 0## and hence in this case what you have inferred is correct.
But in general, ##\mathbf E_d## does not have to satisfy this condition. For example, imagine a long rod of length ##L## made of dielectric material, with permanent and uniform polarization ##\mathbf P## pointing along the long axis of the rod and with cross-section ##\Delta S##. The bound charges appear only at the ends of the rod, and their electric field is that of a dipole of charge ##P \Delta S## and length ##L##, non-uniform and non-zero almost everywhere in the vacuum and the rod. This is very different field from the polarization field, which is uniform in the rod and zero in the vacuum.
In electrostatics, the polarization ##\mathbf P## is best defined as expected average dipole moment of molecules that have at least some part in a small control volume divided by this volume (the volume should contain many , say >1000 molecules) or better, as expected average dipole moment of one molecule times number density of molecules.
tiny-tim said:
hi sigma_! :smile:
Thank you! your post prompted me to do a little more algebra, keeping what you just said in mind.
Of course! P can absolutely be larger in magnitude than the total field in the dielectric!
Dear student,
Thank you for sharing your thoughts and questions about the electric displacement field. It is clear that you have been working hard to understand this concept, and I am happy to provide some guidance and clarification.
Firstly, it is important to understand that the electric displacement field, D, is a mathematical construct that helps us understand and describe the behavior of electric fields in dielectric materials. It is not a physical quantity that can be measured directly, but rather a theoretical tool that allows us to simplify and analyze complex systems.
Now, let's address your specific questions and concerns:
Your understanding of the physical interpretation of the displacement field is correct. The displacement field takes into account the contribution of both the free charges and the polarization of the dielectric material. The polarization is indeed in the opposite direction of the applied field, which creates an opposing field that weakens the overall electric field within the material.
2) and 3) are simply mathematical representations of the physical relationship between the electric displacement field and the electric field. In equation 2), we see that the polarization, P, is proportional to the electric field, E, through the dielectric constant, χe. This is a general relationship for linear, isotropic, homogeneous dielectric materials. In equation 3), we substitute this relationship into the definition of the displacement field, D, to show that it is directly proportional to the electric field, E.
To address your confusion about the magnitude of the polarization in equation 2), it is important to remember that the dielectric constant, χe, is a dimensionless quantity. Therefore, it does not have the same units as the electric field, and it is not directly comparable. The dielectric constant simply tells us how much polarization will occur for a given electric field strength.
FAQ: Understanding the Electric Displacement Field
1. What is the Electric Displacement Field?
The Electric Displacement Field, also known as the D-field, is a concept in electromagnetism that describes the amount of electric flux per unit area that passes through a given surface. It is a fundamental concept in understanding the behavior of electric fields in different materials.
2. How is the Electric Displacement Field different from the Electric Field?
The Electric Field, symbolized by E, is a vector quantity that describes the force per unit charge exerted on a test charge by an electric field. The Electric Displacement Field, symbolized by D, takes into account the effects of free and bound charges in a material, and is therefore useful in situations where the electric field is influenced by the presence of different types of charges.
3. What is the relationship between the Electric Displacement Field and the Electric Polarization?
The Electric Polarization, symbolized by P, is a measure of the dipole moment per unit volume of a material. The Electric Displacement Field is directly proportional to the Electric Polarization, with the constant of proportionality being the permittivity of the material. This relationship is described by the equation D = εP, where ε is the permittivity.
4. How is the Electric Displacement Field useful in practical applications?
The Electric Displacement Field is useful in understanding the behavior of electric fields in different materials, which is important in a variety of practical applications. It is used in the design and analysis of electronic devices, such as capacitors and transistors, as well as in the study of dielectric materials and their properties.
5. How is the Electric Displacement Field related to Gauss's Law?
Gauss's Law states that the electric flux through a closed surface is proportional to the enclosed charge. The Electric Displacement Field is directly related to the electric flux, and therefore plays a crucial role in understanding and applying Gauss's Law. It allows us to calculate the amount of electric charge contained within a given volume, and is useful in solving a variety of problems in electromagnetism.
48K
