Understanding the Electric Field of a Charged Sphere
In summary: So if you think about it, treating a sphere as a point charge makes sense because there's really nothing inside the sphere to interfere with the electric field.
Leo Liu
353
156
Just a random question about electricity.
$${E} = {{kQ} \over {r^2}}$$
This page claims that "[t]he electric field outside the sphere is given by: ##{E} = {{kQ} \over {r^2}}##, just like a point charge". I would like to know the reason we should treat the sphere as a point charge, even if the charges are uniformly distributed throughout the surface of the conducting sphere. Also, is this statement valid for a non-conducting charged sphere? Thank you.
Update:
Reading this thread I realized that I can create a spherical Gaussian surface outside the conducting sphere and ##\oint{E}\mathrm{d}A = {E4\pi r^2} = {Q \over \epsilon_0} ##, which implies its electric field is the same as the electric field of a point charge, yet I still don't intuitively understand why it holds ture.
The main difference between the conducting sphere and the point charge is that the field inside the sphere is zero; the equation you derived is only true outside the sphere.
By the way, the electric field is a vector field, so you really should indicate the direction of the field.
jason
jason
Hi, thank you for replying. I understand that the strength of the field inside a conducting spherical shell is 0 since the excess charges tend to stay on the outer surface of a conductor and ##dA ## from every direction cancels out. However, is this valid for an insultor given that the charges inside are uniformly distributed?
Leo Liu said:
Hi, thank you for replying. I understand that the strength of the field inside a conducting spherical shell is 0 since the excess charges tend to stay on the outer surface of a conductor and ##dA ## from every direction cancels out. However, is this valid for an insultor given that the charges inside is uniformly distributed?
Yes. You can deconstruct a solid sphere of uniform charge distribution into a set of concentric shells. If you know it's true for the outside surface then it will also be true for the next-most outside shell, etc. Because of the superposition property of EM you can add solutions together (or subtract) to make a new solution.
Likes hutchphd and Leo Liu
It is true for a charge uniformly distributed on a spherical shell, and hence also for a sphere in which the charge density depends only on radius. Similarly for any force field follwing an inverse square law, such as gravitation.
It follows that it is true for a conducting spherical shell in the absence of any other field. But, e.g., if there is a point charge in the vicinity then the charge will not be uniform.
Likes Leo Liu
In the case that a point charge is placed closed to the sphere, is it correct to say that the charge distribution on the surface cannot be uniform because the point charge will attract some charges with oppsite sign in the sphere (and repel the others)?
Yes and you can say that the field inside the conductor will be zero. The rest of the story gets more complicated (but do-able e.g. method of images)
Assuming the point charge is outside.
Leo Liu said:
Homework Statement:: Just a random question about electricity.
Relevant Equations:: $${E} = {{kQ} \over {r^2}}$$
Update:
This is the "shell theorem", which applies to any inverse square field. Usually to Newtonian Gravity and Electrostatics. See, for example:
https://en.wikipedia.org/wiki/Shell_theorem
The mathematics is essentially the same for electrostatics.
Likes Leo Liu
Related to Understanding the Electric Field of a Charged Sphere
1. What is an electric field?
The electric field is a physical quantity that describes the influence that a charged object has on other charged objects in its vicinity. It is a vector quantity, meaning it has both magnitude and direction.
2. How is the electric field of a charged sphere calculated?
The electric field of a charged sphere can be calculated using the formula E = kQ/r^2, where k is the Coulomb's constant, Q is the charge of the sphere, and r is the distance from the center of the sphere to the point where the electric field is being measured.
3. What is the direction of the electric field of a charged sphere?
The direction of the electric field of a charged sphere is radially outward from the center of the sphere if the charge is positive, and radially inward if the charge is negative. This means that the electric field lines point away from a positive charge and towards a negative charge.
4. How does the electric field of a charged sphere change with distance?
The electric field of a charged sphere follows an inverse square law, meaning that it decreases in strength as the distance from the sphere increases. This means that the electric field is strongest closest to the sphere and gets weaker as you move further away.
5. What are some real-life applications of understanding the electric field of a charged sphere?
Understanding the electric field of a charged sphere is important in many fields, such as electronics, physics, and engineering. It is used in the design and operation of electronic devices, such as capacitors and batteries. It also helps in understanding the behavior of lightning and other atmospheric phenomena. Additionally, the concept of electric field is crucial in understanding the principles of electromagnetism and its applications in technology.
