Understanding the Impact of Dielectric Insertion on Capacitance
In summary, the derivation for the capacitance of a parallel plate capacitor takes into account the uniform electric field, infinite plate area, and perfect conductors. The application of Gauss' law to a rectangular prism results in a formula for capacitance that is independent of the electric field strength. However, when a dielectric material is inserted, the electric field is reduced due to polarization of molecules, resulting in an increase in capacitance. This is because the induced charge must be taken into account when calculating the charge enclosed by the volume. This explanation reconciles the difference in capacitance before and after inserting a dielectric.
moderate
A derivation of the capacitance for a parallel plate capacitor is as follows:
[ assume uniform field, plate area is infinite in relation to the separation, the conductors are perfect conductors ]
So, V=Ed
where
V=voltage difference between plates
E= electric field (uniform)
d=separation distance
Also, apply Gauss' law to a surface that is a rectangular prism, with one plane passing through the conductive plate and another plane passing perpendicularly through the field E. Dotted lines: planes of Gaussian surface. Solid line: plate. Plus signs: positive charge.
____________
result of Gauss' law:
EA=q/[tex]\epsilon[/tex]o
q=EA[tex]\epsilon[/tex]o
dividing:
C=q/V
C=EA[tex]\epsilon[/tex]o / Ed
C=A[tex]\epsilon[/tex]o / d
Supposing a dielectric material is inserted. The insulator's molecules become somewhat polarized, and an induced negative charge appears next to the plate containing the positive charge (and vice versa).
The net result is the reduction in the electric field E. As a consequence, the voltage across the capacitor drops (for an isolated capacitor), and the capacitance (C') increases (from C=Q/V).
I am having difficulty reconciling this explanation with the above derivation for the capacitance.
As can be seen from the red equation, the strength of the electric field cancels out, and does not affect the capacitance! But, the capacitance is clearly different after the dielectric is inserted! What is going wrong?
I am thinking that maybe Gauss' law is no longer applicable, but I can't figure out if this is true/why.
As a first thought, [tex]\epsilon[/tex]o is the permittivity of air. Once you insert the dielectric, you have to replace that with [tex]\epsilon [/tex] which will reflect the permittivity of the dielectric itself.
This is also assuming it's a linear dielectric.
I've figured out why I was wrong (by looking in a textbook).
What was wrong was that for the second case, the induced charge needed to be taken into account.
So, the charge enclosed by the volume was no longer q, but was q-q', where q' is the induced charge of the opposite sign.
Once that's considered, the capacitance is no longer the same as without a dielectric. :-p
(maybe using a different permittivity would lead to the same end result? I don't know)
Related to Understanding the Impact of Dielectric Insertion on Capacitance
1. What is a dielectric insertion and how does it affect capacitance?
A dielectric insertion is the introduction of a new material between the plates of a capacitor. This material, known as a dielectric, changes the capacitance of the capacitor by altering the electric field between the plates. The dielectric has a higher permittivity than air, which increases the capacitance of the capacitor.
2. How does the thickness of the dielectric affect the capacitance?
The thickness of the dielectric has a direct impact on the capacitance of the capacitor. The thicker the dielectric, the higher the capacitance will be. This is because a thicker dielectric allows for more electric flux to pass through, resulting in a stronger electric field and therefore a higher capacitance.
3. What is the relationship between the dielectric constant and capacitance?
The dielectric constant, also known as relative permittivity, is a measure of how much the dielectric material can store electric charge. It is directly proportional to the capacitance of the capacitor. This means that as the dielectric constant increases, so does the capacitance of the capacitor.
4. How do different types of dielectric materials affect capacitance?
Different types of dielectric materials have different dielectric constants, which in turn affect the capacitance of the capacitor. Materials with higher dielectric constants, such as ceramics and certain plastics, will have a greater impact on capacitance compared to materials with lower dielectric constants, such as air or paper.
5. Can dielectric insertion be used to increase or decrease capacitance?
Yes, dielectric insertion can be used to increase or decrease the capacitance of a capacitor. By choosing a dielectric material with a high or low dielectric constant, the capacitance can be increased or decreased respectively. However, it is important to note that the thickness and other factors of the dielectric material also play a role in the final capacitance value.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
