Understanding the Lemaitre metric
  • Thread starter yuiop
  • Tags
    Metric
In summary, the article discusses the Schwarzschild radius and the equivalence of the Lemaitre and Schwarzschild metrics. It states that the Schwarzschild radius is equal to the constant Schwarzschild radius, which implies that the Lemaitre metric is equivalent to the Schwarzschild metric.
yuiop
3,962
With reference to this wikipedia article http://en.wikipedia.org/wiki/Lemaitre_metric
it states
[tex]r = \left(\frac{3}{2}(p-\tau)\right)^{2/3}\ r_g^{1/3} [/tex]
and
[tex] r_g = \frac{3}{2}(p-\tau) [/tex]
Those two statements put together imply
[tex]r = \left(\frac{3}{2}(p-\tau)\right)^{2/3} \left(\frac{3}{2}(p-\tau)\right)^{1/3} [/tex]
[tex]r = r_g[/tex]
This in turn implies the Schwarzschild radial variable r is equal to the constant Schwarzschild radius [itex]r_s = 2gm/c^2[/itex] and this leads to the Lemaitre metric being equivalent to
[tex] ds^2 = d\tau^2 - dp^2 [/tex]
and when [itex]r_g/r = 1[/itex] is inserted into the Lemaitre coordinate definitions:
[tex]\begin{cases}
d\tau = dt + \sqrt{\frac{r_{g}}{r}}\frac{1}{(1-\frac{r_{g}}{r})}dr~,\\
d\rho = dt + \sqrt{\frac{r}{r_{g}}}\frac{1}{(1-\frac{r_{g}}{r})}dr~.
\end{cases}[/tex]
the result is:
[tex]\begin{cases}
d\tau = dt \pm\ \frac{dr}{0}~,\\
d\rho = dt \pm\ \frac{dr}{0}~.
\end{cases}[/tex]
Obviously I am missing something important here. Can anyone clarify?
kev said:
Obviously I missing something important here. Can anyone clarify?
Those points are not covered by a Schwarzschild coordinate chart. Your observation is a manifestation of the coordinate singularity of Schwarzschild coordinates that prevents them from being extended any further.
What exactly do you mean by "those points"?
When the article states
I assume it is referring to r everywhere (including outside the event horizon where the Schwarzschild metric is valid) and not just to the event horizon or points below the event horizon. Is that wrong?
The ones at the "gravitational radius" -- [itex]
[/itex].
[/itex].
OK. So if I want to plot a constant Schwarzschild radius in Lemaitre [itex](p,\tau)[/itex] coordinates I should use a constant value for [itex]r_g[/itex] in the equation:
[tex]r = \left(\frac{3}{2}(p-\tau)\right)^{2/3}\ r_g^{1/3}\ [/tex]
which results in a diagonal line parallel to the Lemaitre gravitational radius?
No, you should plot the points satisfying [itex]
[/itex].
[/itex].
So a line of constant Schwarzschild radius (other than the gravitational radius) can not be transformed into a Lemaitre chart??
Oh, you're talking about the Schwarzschild radial coordinate! I thought you were talking about the Schwarzschild radius.
Yes, you had the right equation.
But what is the right way to use it?
If I substitute the definition given for [itex]r_g[/itex] into the equation for the definition of the Schwarzschild radial coordinate in terms of Lemaitre coordinates I end up with [itex] r = r_g[/itex] as mentioned in the OP, which is most unsatisfactory. :confused: I have never seen null worldlines and Schwarzschild radial coordinates plotted on a lemaitre chart so I am trying to do it for myself. Maybe everyone else has hit upon the same problems.
rg is the Schwarzschild radius. [itex]
[/itex] is not a definition of rg. It is the equation of the event horizon -- it is valid only for those [itex](\tau, p)[/itex]-pairs lying on the event horizon, which is why, if you invoke that equation, you derive r=rg.
OK, that seems reasonable. Using rg as a constant, lines of constant Schwarzschild radius are parallel but diagonal lines in Lemaitre coordinates.
Now I want to obtain an equation for null worldlines that can be plotted on the Lemaitre chart. Starting with the Lemaitre metric:
[tex]ds^{2} = d\tau^{2} - \frac{r_{g}}{r} dp^{2} [/tex]
and taking ds = 0 for a null worldline, then
[tex]dp/dt = \sqrt{ \frac{r}{r_g}} [/tex]
By inspection it can be seen that for r = 0, r = rg and r = [itex] \infty[/itex] that dp/dt for a lightlike path is 0, [itex]\pm 1[/itex] and [itex]\pm \infty[/itex] respectively.
Substituting
into
[tex]d\tau = \sqrt{ \frac{r_g}{r}} \ dp [/tex]
gives
[tex]d\tau = \left(\frac{2\ r_g}{3(p-\tau)}\right)^{1/3} \ dp[/tex]
now it looks like multi variable integration is required at this point to obtain an expression that can be plotted. Is there anyone here who is handy with advanced calculus that would be kind enough to do that calculation?
In Lemaitre coordinates,
[tex]dS^2 = dt_{(proper)}^2 =\ \left( d\tau^2 - \frac{r_g}{r}dp^2 \right) [/tex]
a "stationary observer" is free falling and when dp=0,
[tex]\frac{dt_{(proper)}}{d\tau} = 1[/tex]
as you would expect.
The speed of light in these coordinates when dS=0 is
[tex]\frac{dp}{dt} =\sqrt{{\frac{r}{r_g}[/tex]
so at r = infinity, the speed of light is infinite also. At asymptotic infinity, the spacetime becomes almost flat or Minkowskian and the free falling velocity of an observer is almost zero, so it seems very strange that the observer should measure the speed of light to be infinite when he is almost stationary in flat space. I guess that is a quirk of how distance is defined in these coordinates?
Lemaitre coordinates claim to "prove" that light can only travel inwards below the event horizon and yet no one on this forum is able to derive the equation for a null path in these coordinates or even to quote an equation for the null path from a textbook?
Perhaps it isn't clear what you are asking. The equation for a null path, in terms of any coordinate system, is ds = 0. Lemaitre coordinates don't claim to prove anything, they are simply one of infinitely many possible systems of coordinates that satisfy the field equations with spherical symmetry. Anyone who understands differential manifolds with semi-definite metrics can infer the light cone structure from any such system of coordinates. Of course, you have to be careful with statements like "light can only travel inwards..." because this ignores the "white hole" portion of the fully extended vacuum solution. I think it's best to learn the basics of calculus and physics before trying to evaluate the validity of general relativity.
FAQ: Understanding the Lemaitre metric
What is the Lemaitre metric?
The Lemaitre metric is a mathematical description of the geometry of the universe proposed by Belgian physicist Georges Lemaitre. It is a solution to Einstein's field equations in general relativity and describes the expansion of the universe in terms of time and space.
How does the Lemaitre metric differ from other models of the universe?
The Lemaitre metric differs from other models, such as the Friedmann-Lemaitre-Robertson-Walker (FLRW) metric, in that it takes into account the effects of radiation on the expansion of the universe. This makes it a more accurate model for the early stages of the universe.
What are the main features of the Lemaitre metric?
The main features of the Lemaitre metric include a singularity at the beginning of the universe, a scale factor that describes the expansion of the universe, and a term for the density of matter and radiation. It also predicts a deceleration in the expansion of the universe due to the effects of gravity.
How does the Lemaitre metric relate to the Big Bang theory?
The Lemaitre metric is closely related to the Big Bang theory, as it describes the expansion of the universe from a single point of infinite density and temperature. The singularity in the Lemaitre metric is equivalent to the initial singularity in the Big Bang theory.
What is the significance of the Lemaitre metric in modern cosmology?
The Lemaitre metric is significant in modern cosmology as it provides a mathematical framework for understanding the expansion of the universe and its evolution over time. It has also been confirmed by observations and is used in conjunction with other models to better understand the structure and history of the universe.
