Understanding the Longitudinal Wave Velocity of a Helical Spring
In summary, the longitudinal wave velocity on a helical spring can be calculated using the formula v = [sqrt(D/m)] * L, where D is the spring constant, m is the mass of the spring, and L is the length of the spring. This formula is derived from the general speed of wave and can also be found in a more detailed derivation. The transverse wave velocity, on the other hand, is dependent on the unstretched length of the spring and can be found in the appendix of a provided source.
Kai
v = [sqrt(D/m)] * L, where D is spring constant, m is mass of spring, L is length of the spring
My lecturer give me this formula to find the longitudinal wave velocity on an helical spring. May i know how to derive this formula?
< Mentor Note -- this is not technically a homework question, but it is okay that it is in the schoolwork forums >
If you start from the general speed of wave, as derived on a string, it actually works to just substitute in the quantities for the spring into this formula. Using your notation,
[tex]
v_c = \sqrt{\frac{T}{\mu}} = \sqrt{\frac{DL}{M \over L}} = L\sqrt{\frac{D}{M}}
[/tex]
The transverse wave [itex]v_t[/itex] is different in that depends on the unstretched length [itex]L-L_o[/itex].
If you don't find that satisfying, you can find a simple but more convincing derivation here. The appendix on page 8 contains their full derivation of it and experimental justification.
http://netserver.aip.org/epaps/phys_teach/E-PHTEAH-46-010803/Hooke's Law Waves Online.pdf
Related to Understanding the Longitudinal Wave Velocity of a Helical Spring
1. What is a longitudinal wave?
A longitudinal wave is a type of mechanical wave that causes disturbances or vibrations in the same direction as the wave travels. This is in contrast to transverse waves, which cause disturbances perpendicular to the direction of the wave.
2. How does a helical spring produce a longitudinal wave?
A helical spring is a coiled wire or ribbon that can store potential energy when compressed or stretched. When released, this energy is converted into kinetic energy, causing the coils to vibrate back and forth along the axis of the spring, producing a longitudinal wave.
3. What factors affect the longitudinal wave velocity in a helical spring?
The longitudinal wave velocity in a helical spring is affected by the material properties of the spring such as density and elasticity, as well as the tension and length of the spring. All of these factors determine how quickly the wave can travel through the spring.
4. How is the longitudinal wave velocity calculated in a helical spring?
The longitudinal wave velocity in a helical spring can be calculated using the equation v = √(T/μ), where v is the wave velocity, T is the tension in the spring, and μ is the linear density of the spring (mass per unit length).
5. Why is understanding the longitudinal wave velocity of a helical spring important?
Understanding the longitudinal wave velocity of a helical spring is important in various fields, including engineering, acoustics, and seismology. It allows for the prediction and control of wave behavior in springs, which is essential in the design and operation of many mechanical systems.
