Understanding the mass of ordinary matter
In summary: I don't understand what you are trying to say about the source of the gravitational field. What does that have to do with my question? Maybe you could explain it in more detail?In summary, the source of the gravitational field is energy. The energy comes from the Higgs field and it is equivalent to the rest mass.
fog37
1,568
108
TL;DR Summary
Conceptual and high level understanding of the mass to ordinary objects
Hello,
The periodic table contains 118 different elements which compose regular matter and the reality around us. On the other hand, "antimatter" is made of elements not included in the periodic table. As far as the periodic table, I think about 98 elements occur naturally while the other ones are man made. Now, ordinary objects are made of the different elements combined/bonded in different ways. Fundamentally, all elements are made of protons, neutrons, electrons. The total mass of an object is 45% from the neutron, 55% from protons and 0.03% from electrons. Neutrons and protons are made of quarks whose mass is only about 1% of the mass of the protons and neutrons. So all the mass that an object has is not due to the mass of the particles but to the energy stored in the fluctuations of the gluon field which binds quarks together (strong force).
The gluon field is essentially empty space (it has fluctuations) that it is not truly empty but filled with energy, correct? So, fundamentally, the mass of regular matter is mainly energy, as Einstein postulated. I read that the space between quarks has less fluctuations. Does that mean it contains more energy? Is my understanding correct?
Also, if most of the mass or ordinary things is truly a form of energy, what is the origin of the remaining mass? For example, if what is the 0.03% of the electrons' mass made of?
Thanks!
Likes Delta2
fog37 said:
Summary:: Conceptual and high level understanding of the mass to ordinary objects
Well, and anti-deuteron is made up of an antiproton and an antineutron. Take two anti-deuterons and two positrons and you make an anti-deuterium molecule. So, as far as I know, all elements of the periodic table have an anti- counterpart of the same mass.
Also an anti-X meets an X they may annihilate releasing energy equivalent to their mass.
Likes fog37
Antimatter has the same periodic table with the same elements. Antihydrogen is routinely produced as neutral element (antiproton+positron), antihelium-nuclei have been produced as well.
It's not empty. If it would be empty it wouldn't have energy.
I don't know what you read, it sounds strange, but without seeing the source I can't tell.
The mass of the elementary particles in matter comes from their interaction with the Higgs field.
Likes fog37 and vanhees71
Most of the mass of ordinary matter around us, concentrated mostly in the protons and neutrons of the atomic nuclei, does not come from the interaction with the Higgs field but through the not yet completely understood mechanism of confinement, i.e., via the strong interaction.
Likes Delta2, fog37 and Paul Colby
In special relativity, we call rest mass ##m_{rest}## the mass of an object that is at rest relative to the reference frame (observer). Rest mass and energy are related through the famous equation below: $$E=m_{rest} c^2$$ Based on our discussion above, the mass of any ordinary object is the rest mass. And the majority of the rest mass ##m_{rest}## is fundamentally energy related to gluon field, quark confinement, etc., Only a small portion of the rest mass is due to the Higgs field mechanism.
So also the small amount of rest mass due to the Higgs field mechanism is equivalent to energy, correct? The rest mass ##m_{rest}## in the above equation does not specify a particular type of mass and its origin and just includes all rest mass. Is that correct? So, in summary, the rest mass consists of a portion (the majority) due to the strong force and a minor portion due to the Higgs field mechanism. But both are fundamentally the same type of energy...
Likes Delta2
Allow me to jump in, the mass that generates gravity is from the Higgs mechanism, the confinement mechanism or from both?
The source of the gravitational field, according to general relativity, is not mass but the energy-momentum-stress tensor. In GR inertia and the source of the gravitational interaction are due to energy, momentum, and stress rather than due to inertial and gravitational mass as in Newtonian physics, which explains within GR, why inertia and sources of the gravitational field are the same by construction (implementing the strong equivalence principle).
I am not sure i understand this, and how exactly it answers my question. Since the source of the gravitational field is energy, this energy comes from the higg's field and from the strong force field?
Likes Imager
The source of the gravitational field is the energy-momentum tensor of all the non-gravitational fields, describing matter and radiation. Part of it is also the Higgs field. For the matter surrounding us the contribution of the Higgs field to the mass of the protons and neutrons is about 2% of their total mass. Most of the mass is due to the strong interaction, as already kind or explained above. One should, however, keep in mind that confinement of QCD is not fully understood yet.
Likes Imager and Delta2
Elementary particles have all their mass due to the higgs mechanism. Is that correct? But composite particles like proton and neutron, have most of their mass due to the confinement mechanism. Is that correct?
No. Positronium gets its mass from the Higgs mechanism.
Likes vanhees71
Positronium is kinda of exotic. When i was saying composite particle i had in mind some sort of particle consisting of other particles held together by the strong force. But ok that was good to mention, you made me realize that there are composite particles that are hold together by other forces other than the strong force.
Thank you all. Just so I can follow, if a book has a mass of ##m_{rest}=5 Kg##, that represents its rest mass and we know it is equivalent to an amount of energy equal to ##E = m_{rest} c^2##. That different portions of that rest mass has two different origins which are the Higgs mechanism and QCD confinement.
While in SR, ##m_{rest}## represents a simple scalar parameter, in GR the concept of mass has a more sophisticated and different meaning...
All things discussed have very little to do with GR.
It's still not true in general. If you take particles that contain heavy quarks then most of their mass comes from these heavy quarks. Hadrons with only light quarks (like protons, neutrons and pions) are the outlier here.
Likes vanhees71
Related to Understanding the mass of ordinary matter
1. What is the definition of mass in relation to ordinary matter?
Mass is a measure of the amount of matter in an object. It is a fundamental property of matter and is often measured in units of kilograms (kg).
2. How is the mass of ordinary matter determined?
The mass of ordinary matter is determined by measuring the amount of matter in an object using a balance or scale. This measurement is typically compared to a standard unit of mass, such as the kilogram, to determine the exact mass of the object.
3. Why is understanding the mass of ordinary matter important?
Understanding the mass of ordinary matter is important because it allows us to accurately measure and compare objects, as well as predict their behavior. Mass is also a key factor in many scientific equations and theories, such as Newton's laws of motion and Einstein's theory of relativity.
4. How does the mass of ordinary matter affect its properties?
The mass of ordinary matter can affect its properties in various ways. For example, the amount of matter in an object can determine its density, strength, and ability to resist changes in motion. It can also affect its chemical and physical properties, such as melting point and boiling point.
5. Can the mass of ordinary matter change?
The mass of ordinary matter is generally considered to be constant and does not change. However, in certain situations, such as nuclear reactions or when matter is converted to energy, the mass of an object can change. This is described by Einstein's famous equation, E=mc^2, where E represents energy, m represents mass, and c represents the speed of light.
