I Understanding the thrust generated by a typical jet engine
The discussion focuses on understanding the thrust generated by different components of a jet engine, particularly the compressor, diffuser, combustion chamber, turbine, and nozzle. It highlights that thrust is generated through pressure interactions, with the compressor increasing pressure and the diffuser maintaining it despite temperature changes. The combustion chamber presents a challenge, as it experiences a pressure drop, raising questions about its contribution to thrust. The turbine and nozzle generate thrust in the opposite direction, necessitating energy input to maintain flow speed, which is crucial for net thrust. The conversation emphasizes the complexity of jet propulsion and invites further exploration of optimization strategies.
JD_PM
I was reading propulsion chapter 9 of Anderson's Flight book (http://213.230.96.51:8090/files/ebooks/Muhandislik/Anderson J.D. Introduction to flight (8ed., MGH, 2016)(ISBN 9780078027673)(O)(929s) EAs .pdf) and came to Figure 9.18 b) & c), Figure 9.19 (I cannot post the image here due to copyright reasons), which shows the thrust associated to each part of the jet engine.
I want to understand how to physically justify the thrust linked to each part of the jet engine, as shown in Figure 9.19.
It should be justified once the pressure distribution along the engine is understood. Assuming an isentropic, ideal gas, I based my reasoning in Newton's third law.
Compressor. The flow exerts pressure (over certain area) on the compressor blades and these exert the same pressure on the flow in the opposite direction, generating thrust. The pressure increases across the compressor because the cross-sectional area decreases through the compressor (the thrust across the compressor ##T_c## increases but I assumed that the latter does so "slower" than the cross-sectional area).
Diffuser. The flow exerts pressure (over certain area) on the tip of the combustion chamber, which exerts the same pressure on the flow in the opposite direction. Despite being a diffuser, we observe that the pressure increases; that has to do with the increase in temperature (this can be seen via the isentropic relation ##\frac{p}{p_0} = \left( \frac{T}{T_0} \right)^{\gamma/(\gamma-1)}##).
Combustion chamber (CC). Here things become interesting. Despite the huge increase in temperature, the pressure experiences a sudden decrease right at the beginning of the CC and the value remains constant throughout. The cross-sectional area cannot justify this so I am still thinking what argument could do.
How can we justify the CC contribution to the thrust? The flow exerts pressure (over certain area) on the the ending part of the combustion chamber, which exerts the same pressure on the flow in the opposite direction.
I have been trying to use the same argument to justify why the thrust linked to the turbine and the convergent nozzle points in the opposite direction but did not come up with a convincing answer yet.
What could be done to optimize the net thrust? I thought the key should be on reducing the thrust linked to the turbine and the convergent nozzle given that they are the responsible for generating an opposite thrust. However, these are necessary in order to increase the flow's speed (we know, due to Mach number-pressure relation (Aerodynamics Anderson EQ. 8.42 https://aviationdose.com/wp-content/uploads/2020/01/Fundamentals-of-aerodynamics-6-Edition.pdf), that if the pressure decreases the speed increases), which is essential in order to generate net thrust.
I find propulsion absolutely fascinating so please feel free to discuss beyond!
The turbine is pitched and geared to extract energy from the flow, so the force on it in the direction of the flow (backwards). To generate a force opposite to the relative flow, you need to supply energy via the shaft (as happens at the compressor).
Here is a nice riddle that goes to the basic physics of a turbojet:
https://www.av8n.com/physics/jet-riddle.htm
Likes gmax137 and JD_PM
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
