HermanTheGerman
Hi there,
I have a question concerning the etalon (One would think that I find an answer for this in every standard physics textbook or this forum, but I actually did not):
An etalon can be built from a solid block of glas (for example) with dielectric high reflectivity coatings (let's say R=99 %) on both sides. For the right wavelength their transmission can get close to unity. I understand that constructive interference of the beams reflected inside the cavity is the reason for this. Here is the part that I don't understand: If the outer surfaces reflect 99 % of the light, I would assume that only 1 % of the light can enter the etalon and undergo constructive/destructive interference. The other 99 % are reflected back to the laser at the very first surface and thus cannot interfere with something. So how can the etalon transmit overall almost 100 % of light (if it has the right wavelength) if 99% are reflected away from the etalon?
Or to cut a long story short: I don't understand why most light is transmitted at the surface when coming from the outside, but mostly reflected when coming from the inside. In my understanding dielectric reflectivity surfaces should work the same in both directions.
I would be glad if someone can help me understanding this effect.
Greetings, HermanTheGerman
